16v inlet manifolds
Discussion in '16-valve' started by southwest_16v, Jan 28, 2004.
  1. southwest_16v Forum Member
    could someone please show me 2 pics - one of a 42mm inlet manifold and one of a 50 mm inlet manifold.i have had the differences described but i still cant make up my mind on what mine is! [:s] thanks.
  2. harry_the_cake Forum Junkie
    Antarctica
  3. southwest_16v Forum Member
    nice cheers harry.
  4. NutterKam Forum Member
    Which one is actually better?? According to the news clipping in the link above it should be the smaller 42mm. Anyone? I've got both (obviously, not one the car :lol: ) and would liketo know which one is best to put back on...
  5. daveybwoy Forum Member
    1.8L 50mm...................2L 42mm
  6. NutterKam Forum Member
    I see.... I've got a 1.8 16V - bog standard - so which one should I use? Cheers
  7. GVK
    I would use the 42mm for a road car, gives better mid range torque.
    I've got one on mine :)
    Edited by: G_V_K
  8. NutterKam Forum Member
    [:D] sounds good to me - thanks
  9. kerrly Forum Member
    STROUD
    has anyone tried using the larger 50 mm top section (larger part) with the smaller 40mm bottom section for a best of both set up?
  10. martyn_16v Forum Junkie
    behind the sofa
    nononononnono, without some serious fettling to the manifolds that would be worse than the worst characteristics of each manifold rolled into one. There'd be a nasty step in the runners that would hinder airflow considerably.
    There was a guy in the states who had a go at taking the best bits from each manifold and rolling them into one though. He got a 50mm manifold, shortened the runners a bit and welded the larger plenum from the 42mm manifold on to it. The results were OK, but not ground-breaking, didn't really look worth the effort (particularly considering the silly prices 50mm manifolds go for over there).
  11. DAVE 2227 Forum Junkie
    Three sizes.
    41mm 42.5mm and 50mm.
    Raised casting on No1 inlet for 41mm
    No casting mark on 42.5mm
    Irregular shape on 50mm.
    I have 41mm on my 16V and it was noticeable difference mid range over 50mm.
    Albeit it wasn`t setup properly either way.
