Inlet manifolds on mk. 2 16Vs
Discussion in 'Engines' started by Aquablue, Aug 22, 2005.
  1. Aquablue Forum Member
    Medway, Kent.
    I'm sure I've read this somewhere before, but I can't find it! Is it right that there are 42mm, 48mm and 50mm size inlet manifolds? Also do all sizes fit the KR engine? Is it also correct that the smaller the size inlet manifold, the quicker lower down acceleration it will have, but the bigger size one's have a higher top-end speed on motorways?
    What would you say is the best overall size to go for?
    Any info, greatly received!
    Edited by: Aquablue
  2. Deako Paid Member Paid Member
    ReddiWraps
    40mm, 42mm and 50mm
    All fit the KR, but you will need the appropriate gasket set.
    The smaller the inlet tract, the more torque they tend to produce at the sacrifice of a little top end power.
  3. Aquablue Forum Member
    Medway, Kent.
    I've got 42 & 50mm, so could fit either. By top end power do you mean flat-out on the motorway, or over 70/80ish? Which would you go for?!
  4. iguana Forum Member
    Samoa
    Top end = high revs
  5. GVK
    I changed from small to large (42mm to 50mm) all I gained was 1 bhp and more noise.. and maybe a few more rpm to play with. :lol:
  6. copper Forum Member
    Got a 50 and it goes like stink past 4k defo where all the power comes in on these. gona try a 42 shortly see how much of the drivability changes ;)
  7. GVK
  8. Aquablue Forum Member
    Medway, Kent.
    Would be very interested in seeing your findings. Interesting reading GVK's link, but not sure how different the readings will be with a standard unmodified '91 1.8?
  9. GVK
    You'll find with the 42mm you won't have that kick at 4k as you'll have more useable power below 4k and the power delivery will have been smoothened out.
    Some like for their car to do nothing until 4k, some don't.. up to you. [:D]
  10. flusted Forum Member
    Kazakhstan
    ive just binned my 50mm for the smallest 1,cars is so much better to drive now
  11. Aquablue Forum Member
    Medway, Kent.
    Think I'll do the same, as it's not that often that I'll be going over 4000rpm, as I don't do that much motorway driving & if I do I rarely go over 90!
    Edited by: Aquablue
