ABF inlet manifold on kr
Discussion in '16-valve' started by flusted, Oct 3, 2005.
  1. flusted Forum Member
    Kazakhstan
    will it fit and would there be any gains to be had due to single butterfly and long smooth runners?? Ive already ditched the 50mm jobby and fitted the early mk2 jobby! Noticed the early mk2 1 has longer runners than the standard corrado 1 aswell
  2. badger5
    nr Glos
    large but obstructed throttle plate.. on ABF
    injectors? fuel rail etc?
    wot setup you running now?
  3. Golden Forum Junkie
    Large single butterfly on K Jet would be a bad idea, there's less progression of air speed which will hurt pick up and part throttle operation.
  4. GVK
    Don't tell him that, he's already got some mad single butterfly throttle body on it :p
  5. flusted Forum Member
    Kazakhstan
    i ditched my huge tb cos it seemed to pull amazing down low but it was poo at 4kupwards,and i sold it for 200 ;)
    Id use the abf inlet manifold but with the k-jet injectors and inserts
  6. flusted Forum Member
    Kazakhstan
  7. martyn_16v Forum Junkie
    behind the sofa
    You can't use the ABF manifold and keep k-jet, there's no provision for injector seats in the ABF manifold.
  8. flusted Forum Member
    Kazakhstan
    Thats kinda answered my question! cheers
