What coil packs using the Ford EDIS-4 wasted spark system will acept standard VW 16v HT lead plugs. I have a 16v that will be running DTA or MBE management. Also will I require the EDIS-4 ignition module or any form or ignition amp if using a standalone ECU.
Late Zetec coil pack, warning not very reliable.. I did post some pics here - but looks like I've deleted them http://forums.vwvortex.com/zerothread?id=1563912&page=5 Edited by: GVK
Late zetec as gary said or peugeot ones can be used Depends if the ecus have biult in ignition drivers or not. Best bet is to look on their website for the specs or ask the supplier.
