Difference between 9a and ABf head?
Discussion in '16-valve' started by rajmirch, Dec 1, 2005.
  1. rajmirch Forum Member
    Any one know if there are any?
  2. Trev16v
    Oxfordshireland
  3. rajmirch Forum Member
    damn howd you get the search to work, when i tried it threw up an error!! [:x]
    Thanks mate!!
  4. Trev16v
    Oxfordshireland
    You have to limit the search to 'topic titles only' as opposed to searching entire message texts.
  5. Hotgolf
    Smelly Cornelly
    Will have a few pics of my own kr head on soon, gonna cut one up and have a few more cross sectional ones that aren't on vortex.
  6. GVK
    If the 9A is 92ish or newer, it's EXACTLY the same as an ABF head. On the later 9A/ABF heads the combustion chamber is dished where as the KR /earlier 9A heads have more sharper sides to the CC.
  7. Hotgolf
    Smelly Cornelly
    Yup thats basically it.
    Early KR 026/027 have larger inlet ports(well the divider is smaller) and smaller exhausts
    051 kr 9a heads have smaller inlets(larger dividers) and larger exhausts
    051 early abf same as 9a kr
    053 abf same port design as 9a kr, but with a dished combustion chamber.
    Just checked in the shed again, I have another 051 ABF with the dished chamber.
    Non idea why, but could be down to where it was cast, you never know with those bloody Germans!
    Edited by: Hotgolf
  8. GVK
    Bump for Ray.
  9. Dub Nutta Forum Member
    Gold Coast - Australia
    Gotcha!
    The dished combustion chamber will only be effective with an 82.5mm or greater bore diameter I presume?
