KR cams in ABF
Discussion in '16-valve' started by jaswan, Jan 29, 2006.
  1. jaswan Forum Member
    north east
    hi all,
    quick question....
    my mate has a mk3 16v and iv got some spare kr cams. do we only need to swap the inlet cam for a bit of extra go?
    TIA
    Jason.
  2. Tubthumped Forum Junkie
    Hebden Bridge
    I would leave the standard ABF ones in... are a better set of cams in my opinion.
    People do the KR swap on 9a engines as the 9a cams are poo.
  3. nando Forum Member
    i've tryed the abf/kr cam mix in my old seat and it didn't seem torev well orhave the top end power the abf cams had. could be because of the digifant as the kr cams/mixdo work wellon an abf which is running on k-jet.
  4. jaswan Forum Member
    north east
    so in a mk3 an abf will be slower due to the management?
    cheers .
  5. Tubthumped Forum Junkie
    Hebden Bridge
    And the weight!
  6. nando Forum Member
    i've owned both types, abf on digi and k-jet, both were taken to the same spec i.e kentcams, flowed heads, ex manifolds and setup on RR. digi had 182hp and k-jet 185hp, but the k-jet just feels so much more willing to rev to the redline.:lol:
  7. jaswan Forum Member
    north east
    should i tell him to just keep the stock ABF cams then?
    i dont want him to swap to kr cams and it end up being slower. id look a right .... then
    Jason.
  8. GVK
    Stick with stock. ABF cams are good.
  9. nando Forum Member
    stock abfcams on digi give the best all round, if your mate is after more top end thekent abf264's seemed to work well inmy car.
    Edited by: nando
