16V inlet manifolds
Discussion in 'Engines' started by scox, Mar 10, 2004.
  1. scox New Member
    I have a 1990 16v with the smaller bore inlet manifold, why did vw change them from the old larger 52mm manifolds? Is it worth fitting the old style manifold to improve airflow?
  2. TheSecondComing Forum Addict
    Yes if you want to gain high end power and lose low down torque, no if you don't.
  3. scox New Member
    Don't think I'll bother then, I'm missing the low down torque my 8v had as it is.
    The car is also fitted with a superchips icon box anyone know how much difference these make?
  4. Old skool Cars New Member
    Ireland
    So for top end use the old inlet manifold and for more mid range use the smaller bore inlet?
    Is their any other mechanical differences between the earlier and later 16v's?
    I prefer top end power that the valvers have as compared to 8v's.
  5. flusted Forum Member
    Kazakhstan
    I coverted my corrado from the small to the big!Instead of the semi smooth power delivery with the small 1 you just get a kick up at ass between 4-5k onwards.yes it is a bit flatter upto 4k tho doesnt bother me as ive changed my inlet cam and that gives more lowdown torque anyway
    THER WILL ALWAYS BE A BIG DEBATE ON THIS,BUT IT REALLY IS A CASE OF TRYING IT [:s]
  6. prof Forum Addict
    Suffragette City
    50mms work well on 1.8s 42s are better on a 2.0
  7. scox New Member
    Suppose I'll just have to give it a go then, I have a 50mm manifold anyway so its worth a try.
    flusted, what cam did you use?
  8. gteye Forum Member
    I thought the earlier manifolds were 42mm and the late ones were 50mm.Mine is a 91 and i thought mine was the 50mm one, if you look at the two together the 42mm one is straight whereas the 50mm one has to go narrower where the spark plugs are! also does the colour of the writing on the D.O.H.C tell you whether it is 42mm or 50mm? ie-blue=42mm,red=50mm?
  9. DEX
    Dex Paid Member Paid Member
    the other thing to consider is not just the diameter of the runners, but also the plenum size
  10. jake Forum Member
    Saint Kitts
    how much of a difference is there in plenum size?
  11. prof Forum Addict
    Suffragette City
    and all the throttle bodies are too small
  12. flusted Forum Member
    Kazakhstan
    exhaust cam modified to an inlet cam ;)
  13. flusted Forum Member
    Kazakhstan
    Colours dont tell anything i dont think.
    Early mk2s had the 42mm upto d reg i think then they changed to 50mm till the mk3 which all had 42mm/
    Also all corrados have 42mm
    Correct me if im wrong
  14. davidwort Forum Member
    [:-B] just to be dull:
    Corrado's had the 50mm up to engine no. KR 148313, and all 9A engined (2.0 16v's) had the 42.5mm one
    In fact the part no's are the same for golf 2 16v's and have the same change over point, i.e. they had 50mm ones up to KR148313 and 42.5's after that.
    BUT [:s] ... there is also a 41mm manifold for PL engines... which I don't think we got in the UK anyway!
    Don't argue, this all came off ETKA. ;)
    David.
  15. davidwort Forum Member
    no, no, no, ignore that rubbish, I'm talking crap, it's far more complex than that, apparently some early KR's had the 41mm lower part manifold, the upper only came in 42.5 and 50 on the KR, but PL's had a 41mm upper part too, VW generally in the UK seemed to start with 42.5's on the early UK golf 16v's then change to 50's then back to 42.5's, the early swap from 42.5 to 50 was on a particular chassis number and the later back to 42.5mm based on engine code,
    confused, I know I am [:s] [8-}]
    David.
  16. scox New Member
    flusted, exhaust cam modified to an inlet cam?
    How much difference does it make? Is it a lot of work to modify it, or do you just replace the inlet cam with an exhaust cam?
  17. scox New Member
    Anyone know why vw changed the size of the manifolds?
    Was it to improve low down torque, or for some other reason?
  18. HidRo Forum Member
    Portugal
    i got the 50mm fitted,and didn't noticied any drop of power in low-end,but after 4k,man it goes!! [:D]
    its a good swap.and the mani for free,even better!!! [:D]
  19. KeithMac Forum Junkie
    Kazakhstan
    Bigger manifold was an attempt to get more peak power.
  20. GVK
    I've got a 42mm on my 9A - good enough for 170bhp :p
