Wheel Bolts, Radius or Tapered? Whats the differnce
Discussion in 'Wheels and Tyres' started by altern8, Mar 6, 2008.
  1. altern8 Forum Junkie
    Cocos (Keeling) Islands
    Whats the difference between radius and tapered bolts and how do you know what wheels use what?
  2. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Ones have a radiused head, the others are tapered! ;) :lol:
    If you look at the bolt, the area where the head reduces in size down to the threaded section will either by rounded (a bit like half a sphere). These are `radiused` bolts. If the area is straight (like an upside down cone), it is a `tapered` bolt.
    Looking at the bolt hole in the wheel, you`ll see the area where the bolt `seats`. This will either be `radiused` or `tapered` to match the requisite bolt.
    Only ever use the correct bolt, because the wrong one, when torqued can cause pressure points, because the bolt is not `seating` properly, and could cause stress fractures around the hole and/or eventually work loose.
    Hope that makes sense! :thumbup:
  3. altern8 Forum Junkie
  4. altern8 Forum Junkie
    ahh cheers I just found the pic above too
  5. golf_nuts Forum Member
    Marlow
    It is also good to know that most aftermarket alloy wheels require a 60 degree taper, and standard VW steels utilise the radiused head.
    if you arnt sure, squash a big blob o bluetac into the bolt hole and check what shape it is!
  7. altern8 Forum Junkie
    Just ordered some today 40 posted bit gutting :( but I have to have them i'll post the link later
  8. IanCarvell Forum Member
    Domed ones are usually, but not always used for steel wheels.....and tapers for alloys(usuallly)
    I had a problem when I bought my Mk2 because the genuine VW alloys had tapered seats in them but the bolts were domed....however VW only list the domed ones!
  9. altern8 Forum Junkie
