History GTI Engineering was originally founded by Richard Lloyd in '78. He was racing a Mk1 GTi and went on to win classes in the British Saloon Championship in '77, '78' and '79. These wins also attributed to the launch of this car in the UK. They developed and produced a range of sports conversions. In '82 VAG appointed GTI Engineering Official Audi Volkswagen Conversion Specialists, which meant conversions could be undertaken without affecting the warranty. They became dealer #315. Standard GTI 8v RE2000 Conversion tuftrided EN 24 crankshaft with 94.5mm stroke machined cylinder block of 82mm bore lead-idium heavy duty cranshaft bearings lightened and balanced crankshaft alloy autothermic pistons gasflowed cylinder head with enlarged port diameters gasflowed inlet and exhaust manifolds 42mm inlet valves (40mm on the carb head due to space limitations) 35mm exhaust valve 276 Schrick- (im still deciding between a 276 and 268 as mine had a standard cam fitted) uprated valve springs uprated oil pump windage tray and sometimes an Oettinger baffled sump modified distributor and injection system on the GTI Compression ratio 10:1 Power 8v GTI 152bhp @ 5500rpm 158lbs/ft @ 5500rpm 0-60 7secs 0-100 20secs Max sped 130mph Cars The first Syncro conversion was a LHD Syncro Gt 2 door 90bhp injection model, fitted with a Recaro interior and ABS. A more detailed review can be found in Volkswagen Audi Car magazine Aug '88 or Car magazine May '88. This was also the car featured in the later GTI Engineering brochure and was fitted with their Aero Tech body kit. I have contacted a former employee and they say that 4 conversions were carried out on Golf Syncros, but there is no further information of what spec they were. I only know of the above car an my RE2000 Syncro. Any more info is always appreciated and I would like to meet any others owners! My car It was converted by GTI Eng 10 days before the registration date. When I bought it, it had covered 100k and was almost standard apart from a set of multi-spoke alloys and 16v rear clusters. It was still running on the original re-jetted Pierburg 2E2 carb. It was in reasonable condition and was fitted with the Syncro CL Sports interior. It is keeping the original interior along with a few touches and a late GTI Eng steering wheel that came from a Rallye. I have also pinched the anti-roll bars, exhaust manifold and downpipe. The d/p with have to be modified to fit and Ill have a custom stainless exhaust system. I have fitted FK Konigsport suspension. Im awaiting a Powerflex bush kit, except for the trailing arm bushes. Im fitting a set of eccentric bushes instead. The front brakes have been uprated to 16v spec with a Goodridge brake lead set. The fuel system has also been upgraded with pump and filter/regulater. I am also waiting for a full Missinglinkz tramsmission set and MJ Interiors to do a couple of jobs. There is also a set of VDOs fitted. It was painted up at Volkskraft. Also fitting a Chromalux rear screen Wheels old wheels were ATS motorsport 6x15 new wheels are VW Calmaster from a Golf Country Chrome Paint prep and final finish
Final ride height A few bits and pieces Twin carb teaser These point up! Ive had this car since sometine in 2001. Ive spent all I can when I can and only driven it for 2 months when I first bought it I also contacted the original owner a couple of years ago. His only interest was how fast i get it to go! It came with the original crappy pierburg carb, so the engine was never strained either over its 100k miles I also got a back issue of Volksvagen Driver with the re-released article on the Golf Syncro. It was interesting to see that they mentioned the original LHD GTI Engineering Syncro, and then stated that the conversion was available for RHD, but as far as they know there werent any done.
lovely car, and its good to see something different under the bonnet IDF's?? was the car originally a re2000 running the pierburg? sounds a bit... odd
hi drunkenalan yes it was a bit odd to have the pierburg and ive no idea why the oruiginal owner never fitted a weber ?????? especially after all that engine work. They are 40 DCNF's Hi gazwold yes you did. Its back at volkskraft having the damage repaired to the paintwork. Some theiving ****s robbed the exhaust out of it and damaged just about everything too I never knew who GTI Engineering were when I bought it- i just though golf syncro + 2 litre engine =
I dont doubt it and it should also make much better power than a DCOE conversion too. Ive had the gearbox strengthened by adding the diff bolt kit plus its got a Helix organic clutch with the Sachs Racing pressure plate. If I did this again then id use a cable change box but Rallye boxes were very rare when I sorted that out and i like the feel of a rod-change box
what did you do for a manifold??, i was looking at doing a similar thing a while back but could find a suitable manifold, so abandoned the idea!
drunkenalan- i got lucky and found something already made in germany. A proper cast item. Ill post more pics as i get on with it there are no vids as its been in bits for the last 3 years. It need a visit to a RR and a zorst and im going to refurb the bottom end etc too
You have seen the custom gearnob i made. Remember the ill fated show at Donnongton a while back and a silver Mk2 Driver being ragged around the tyre test circuit
