My Mars Red Mk1 - Thread REBOOT- P82
Discussion in 'Members Gallery' started by vw_singh, May 5, 2008.
  1. vw_singh Events Team Paid Member
    Since getting married in '06, the mk1 (or my bit on the side as my wife calls it) has taken a back seat and gone into hibernation. However, this has allowed me to tackle the car with a bit more care and attention taking my time over renovation and modifications. Quite a lot has changed with some much lager leaps being taken in the cars development. I have tried to carry out as much work as possible in my garage with mates with only extreme specialist work being carried out by tradesmen.
    New spec now stands at:
    - Mk1 Driver shell with strengthened steering mounts converted to full gti running gear, fuel system and late wiring
    - Ground control adjustable spherical top mounts
    - H&R Coilovers rebuilt by H&R to custom spring rates. Replaced with KW-V3's.
    - Neuspeed 22mm front arb with rosejointed ends
    - ABD solid 28mm rear arb
    - BRM Motorsport front lower brace
    - Mk2 16v Rear disc conversion with scirocco 16v handbrake cables
    - 280mm G60 front discs G60 calipers and Epytec adaptors
    - Mk2 servo with 22mm master cylinder
    - Custom widened front wishbones
    - Compbrake adjustable rosejointed track rod ends
    - PWM Ball joint extenders
    - ABF 2.0 16v Engine block
    - Standard ABF head & cams.
    - Megasquirt MS-1 with Squirt'n'Spark Extra
    - Supersprint 4-2-1 exhaust manifold & Group A 60mm exhaust system
    - FD/2Y code gearbox ratios with 4.25 final drive and Quaiffe diff.
    - 6 paddle ceramic clutch. Now OE LUK clutch
    - Lightened flywheel
    - Polybushed where applicable
    - 4 point Willians 4" harness with Aero spec clasp
    - Corbeau Carbon fibre/kevlar composite race seat
    - Fully welded 8 point Custom Cages roll cage.
    Here is the car before hibernation:
    Strengthened steering mounting. Note the L-beam welded in between the mounts:
    GC top mounts in place. These require the raised edge on the top of the strut towers to be removed:
    Work in progress:
    Gearbox bits everywhere:
    ABF waiting transplant:
    Headwork in progress:
    Compbrake rod ends and ball joint extenders (not fitted yet). The rod ends are longer than mk1 stuff but require the taper to be drilled out of the hub carriers.
    Widened wishbones with ARB brackets in place:
    6 Paddle ceramic clutch disc from Bildon Racing:
    Stance anyone?
    BMW BBS alloys just fit. [:s]. 7x15 et 24 fitted with 195-45-15's:
    With plastic GTi arches in place:
    Without plastic GTi arches in place:
    280mm G60 brake disc in place with Calibra carrier in place:
    Getting there slowly:
    There is still some work to go with the head off at the skimmers at the mo and more bits n pieces to clean and paint before fitting along with engine ancillaries to fit before I fire it up and get it road legal. :)
  2. Vento Mike Forum Junkie
    Exmouth
    Looks like it's gonna be a great build, nice one.
  3. altern8 Forum Junkie
    Cocos (Keeling) Islands
    nice work
  4. GVK
    Nice one gurds, should be a good car once finished, the GC top mounts are very nice!
  5. gillm
    gillm ***** User
    yeovil somerset
    red mk1 track car , nuff said good work fella .
  6. seanlazyass Forum Member
    Very nice mate. Well thought out.
    Good stuff and all being well thought through by the looks.
  8. vw_singh Events Team Paid Member
    Engine and box are in along with a few odds and sods.
    Gurds
  9. RIP-MK3 Forum Addict
    sunbury on thames
    quality build!!!! looks awesome
  10. Gaz16v Forum Member
    cool. love the steering wheel
  11. Admin Guest
    what are those wheels???
  12. 1990
    1990 Paid Member Paid Member
    Rochdale, Lancs
    Renault ones?
    The car looks great, nice work!!
  13. vw_singh Events Team Paid Member
    Not Renault wheels. Actually ARC's in 7x15 et25 fitment that belong to a friend. Quite hard to come by.
    Gurds
  14. Hawkesybaby Forum Member
    Tamworth
    I a set off those wheels in garage till about 3 months ago sold them on ot a friend they are nasty on a mk2 but they look really good on m1 i reckon! Great build dude!
    Dan [:o)]
  15. ViCk Forum Member
    Nice one Gurds !
    Finally ... It's all coming together now, I only got mine started with it's new engine a few days ago !
    Lets hope this turns out to be a trouble free motoring year !
  16. steve r
    steve r Forum Member
    Great looking car, looking forward to seeing it on track.
  17. vw_singh Events Team Paid Member
    Thanks for all the positive comments folks. A lot of you have been the source of inspiration with my own project.
    Vick, thought married life had swept you off the scene! Lol. Pop over with your car when you get a chance. I'd like to try on one of your alloys on my car to check clearances.
    Gurds
  18. ViCk Forum Member
    Ah mate ! it's more work than married life !
    Can only mess around with the car every once in a while these days. I'll definately pop down on a weekend sometime tho, take it easy mate.
    P.S PM me your number as I lost my old phone along with all my numbers when u get time. Cheers
  19. Sukh
    Sukh Membership Team Admin
    the driveway
    Gurds,
    Nice motor, theres no way I'm catching that :lol:
    Sukhvir
    Well done on the slalom result :clap: and no doubt the car will be pictured in the VW Driver report.
