hi all ive a 4motion 24v engine 6speed box ,transfor prop rear axle ,stand alone ecu ,shifter etc ,any ideas of the easyist to fit the lot
Buy a 4-MO and stick a MK1 badge on it :-) Rear end and transmission tunnel shall require a bit fabrication work, it will all depend on if its going to be a track car or a road car. Nothings impossible as long as you have an angle grinder and a welder... Mike T of Jabbasport has done a MK1 Scirocco and Golf with syncro setup and i am sure there are a couple of other MK1 done with 4wd kicking about. Do a search for the MK2 golf thats running the audi S2 running gear and that will give you an idea of what can be done.
why buy all the bits for a mommoth job then ask about the easiest way to do it? seems a bit odd to me. To get all this to fit will be a huge job which wich require some good fabrication skills. Im not knocking your intentions or your imagination, but are you ready for all of the head aches?
cheers guys ,ill have a go ,ive poped pics up of work so far ,in mk1 projects/moters,,ill get there one day ,
Shortened audi TT prop through exhaust tunnel Chop + weld mk2 and Audi TT fr and rear driveshafts Machined tubing to make hub carriers to take mk2 Golf wheel bearings Cut out spare wheel for diff Raised rear turrets 6 inch to fit shocks Custom made, rose jointed rear suspension set-up Thats one way
cool idea uuntil id bought a mk4 4motion rear axle i didnt know at the time that a tt could be used ,so my way ,was letting get chopping and just make the buggar fit ,,mines in projects,if u wish to look ,not brilliant but it will work ,,one day lol
Good luck but I wouldn’t, the MK1 is too light and nimble to fit such a lump and running gear in it, 20vt and fwd would make a nimble rocket Good luck with whatever you choose to do
i think its a little late now lol http://www.clubgti.com/forum/showthread.php?p=1588984&posted=1#post1588984 its only because the caddy is a rot box ,and i had the gearing gear cheep ,thought ,pass a few hours on and fit the buggar for a bit of track fun...
Didnt realise the Caddy project was going to be put in a MK1, not fully up to speed as Ive had little internet access over the last week or so. If your going to do it then Id mount the engine and box on a the MK4 mounts by altering the top of the inner chassis rails. Ive done it twice and seen few more do it, makes life easy. Still think it would spoil a MK1, what about an old derby? that would be mint
