K-jet pressure tester
Discussion in 'Tools, Equipment & Fasteners' started by Gaz37, Jan 6, 2009.
  1. Gaz37 The Grouch. Paid Member
    ZZ plural 9 alpha
    Does anyone in, or near, Bristol have a k-jet fuel pressure tester that I could borrow or hire for a reasonable fee?
    I'm happy to pay a deposit to ensure it's returned undamaged or will use at your place if you prefer.
    thanks
  2. Brookster
    M1 J40
    We all had a group buy on here :thumbup:
    think Trev16v is in Bristol with one , he imported them all for us. :)
    Lovely piece of kit
  3. Trev16v
    Oxfordshireland
    I'm in Oxfordshire, sorry; but I'm sure there was someone else in Bristol having one.
    (Brookster: Apologies regarding PM - will get back to you later.)
  4. Mike_H Forum Addict
    Skyrocketeer?
  5. Gaz37 The Grouch. Paid Member
    ZZ plural 9 alpha
    He didn't buy one in the end due to a canelled project.
    I'm gutted cos he lives about 1/4 mile from me[:^(]
  6. 2dubnick Forum Junkie
    Worcester
    I think most of us bristol lot wanted one, but somehow none of us actually put the money forward in time, only myself to blame.
  7. beetie
    beetie Forum Member
    leicester
    check out nigep's members motors thread. he built his own one with bits from a local pirtek.
  8. altern8 Forum Junkie
    Cocos (Keeling) Islands
  9. Nige
    Nige Paid Member Paid Member
    A Copy and Paste from my power thread Down on Power thread
    Using the information on ClubGTi HERE I tested my Fuel control and system pressure.
    Called at my local Pirtek store to buy the necessary fittings.
    Connected up the test gauge / valve
    Started Engine, when settled, saw thew Control pressure which should be 48psi (3.3Bar). Mine was 58psi (4Bar). This is BAD, higher actually means LESS fuel, which is what I was seeing on my plugs compared to before.
    I then closed the Valve to check the System pressure
    This should be around 5 Bar, mine was almost 6 !
    I made a short video to show how to do it (I`ll add this to my build thread later).
    To adjust the Control pressure, I need to adjust to Warm Up Regulator, however, I tried adjusting the WUR and the adjusting allen key made NO difference.
    I later sourced another WUR, that adjusted properly and I was able to set the pressures are required.:thumbup:
  10. bmouthboyo Forum Member
    NigeP Would it be possible to post a shopping list if you will to make this with parts from pirtek?
    Also with rough price of the lot?
    I would love to make one of these but not sure of sizes, threads etc so If i have the list that you bought then I can just show them that :)
  11. bmouthboyo Forum Member
    bump...?
  12. AKAeddypeck Forum Member
    I know this is a really old thread, but I'm looking for the test equipment too.... and just so happen to also be in Bristol.
    Did a shopping list of components ever get put together, or anyone know where to get the kit reasonably priced. Seen sets on eBay for 70 ish, but that's more of a mechanics universal kit with about 80% of the parts surplus I'm sure.
  13. Sirguydo
    Bolton
