the led on the switch doesnt come on and rear fog lights dont come on either. tried new bulbs and swapping the switch for one that definatley works, nothing it doesnt want to play, any ideas????
have you not tried the fuse,its the 10 amp one on the top right of the fuseboard,has grey/white wires on the back
if the above doesnt sort it,then it could be a duff foglamp-relay in the fusebox. if your hazard switch is on the dash then its the bottom left relay.if your hazard switch is on the steering column then the relay youre after is still on the bottom row,but the 4th one from the left. try swapping the suspect relay with an identical one from elsewhere on the fusebox-its a relay thats used for lots of different things so there will be one or two others nearby that you can use to swap with.
ok cool, that means the output from the dash switch works, as they're fed from the same place. one thing i forgot to ask, what year is it?
having this problem also, will look at it tommorrow had no idea there was a relay so glad i spotted this post
re-read orig post,and had assumed wrongly it had front fogs aswell. if its only got a rear foglamp then theres no relay.
i had the same when i fitted new foglights the previous owner had cut a wire at the switch to stop the fuse blowing with the old water filled lights
if both swiches that youve tried dont have the warning light working(and you know one of them definately works) the brown earth wire to the switch could be a suspect,there also looks to be two fuses in that circuit,fuse 6 (15amp)and fuse 27 (10 amp which is the one on top of the fusebox)
replaced both fuses number 6 and the one on the top, the old where looked ok but changed them anyway the earth is a good one ok the wires on the back of the switch with volts from them, grey/yellow 0.06v, white/yellow 0.10v, grey/white 0.13v, brown is earth, grey/blue 12.36v. ami i missing a 12v wire? think the grey/blue is the dimmer wire although not completely sure
grey/white should be +12v with headlamps on and fog light switch on(feed to the lamp) grey/yellow - +12v feed from headlight switch brown -12 earth white/yellow +12v feed to front fogs via fuse 6 grey/blue +12v from illumination
white/yel is the feed to the front fogs, so unused unless they're there have you checked relay #7 clicks if fitted, if its there but doesnt click swap in the other 53 relay from the horn socket. If there isnt one there IIRC there should be a black jumper thing with a grey wire coming out of it pushed into the socket
thanks everybody, its now fixed, was the relay in the end there was a relay there but it had no numbers on it, swapped it with the number 53 like jonny said and bingo! now they worky worky
