intermittent wiper not working
Discussion in 'Mk2' started by DJUPLIFT, Sep 10, 2010.
  1. DJUPLIFT Forum Member
    London
    Hi guys am i right in thinking its a wiper stalk issue when the intermittent wipers dont work?
    i have replaced the relay already and the only setting where the wiper comes on is the fastest setting... anything else the wiper wont move
    any help would be greatly appreciated
  2. DJUPLIFT Forum Member
    London
    bumpage!
  3. alexisblades99 Forum Member
    sunny helsinki
    Have a look behind the stalk where it meets the steering column, see if you can squirt some wd40 in where the switch is, and work it a bit as it might have some corrosion on the contacts.
  4. DJUPLIFT Forum Member
    London
    thanks for that will give it a go fingers crossed it works
  5. pj_sibley
    pj_sibley Forum Member
    Bristol, UK
    Bump...I have exactly this same problem on my new Mk2!! The wipers only work on full speed. Haven't tried the relay yet though, so hoping it's a simple fix [:s]
    DJUPLIFT - did Alexisblades trick work??
  6. mexicorich Forum Member
    North East, United Kingdom
    Isn't this possibly a relay issue for intermitent?
    I though it was also possible to use a Mk3 relay to get variable intermitent timing?
    Can someone remind me my memory is going............
  7. rubjonny
    99 relay from mk3 or passat gives you variable intermittant wipers, if relay doesnt fix then next id try the stalk. it might be the wiper motor itself is buggered tho, or a wiring issue. mk3 golf motor fits, and i think mk4 ones might do as well
  8. M7R
    M7R CGTI Regional Host
    Nottingham
    if it works on full speed the it cant be the motor... it must be a wiring or relay issue as thats what ditermines the speed of the motor
  9. rubjonny
    yeah it can, the motor has all the slow, fast and park gubbins inside it. perhaps the slow speed resistor has packed in ;)
  10. M7R
    Nottingham
    ahh I thought the resistor was else where not actually built into the motor
  11. rubjonny
    ya tis in the motor. another test for if relay is the fault is to use your screen washers, if wiper stikll dont move its not the relay as washers bypass the relay and trigger the motor direct. if washer pump works but wipers dont you know issue isnt the stalks :)
  12. mk216vrick Forum Member
    manchester
    sorry for the thread hijack, but im intrigued. I have a 96 n 2.0 b4 and my intermittant doesnt work, neither do my washer jets turn the wipers on, but all 3 speeds work, would this point at a faulty motor? Iv never bothered looking into the fault as its not a huge issue. But im intrigued! Again sorry to jump in. Rick.
  13. rubjonny
    if wipers work when you pull the stalk, then its the wiper motor. intermediate setting fail would suggest the relay is at fault, if slow and fast both work ok
