NOOOOOOOOOOOOOOOOOOOOOOOO! That heap's not a real ****! This is the last real **** ever built! This is a real 8v motor! I'd even have a 16v if it was this one!
+1 Prof has been warned Leave it to an American or at least an American engine to make a S**B better Runs and hides
click the pics nothing wrong with pushrods makes for a super light & compact engine. the LS series weigh about the same as a vr6 and go to 7.2L
if it hadnt been for the rover v8 you may of just seen that in a triumph apparently they did make one
Crikey - surely the LS engines must have alloy blocks? I'm sure pushrods do offer some advantages, but I'd personally forsake them all for the 4 valves per cylinder and reduced valvetrain mass that a DOHC format allows
different ways to acheive what you want, the LS is all alloy, and tiny due to no dohc. 500bhp and 28mpg is possible at a reletively simple tune, and you can buy a new one for 3k the aftermarket support is huge and parts are quite cheap, a lightweight valvetrain is available and many of them run 7500 revs without issue or go wild and fit the ls9 blower and 427 crank and pistons and have a no nonsense 800bhp. poor output/litre but it's not a big problem when you have 7L to play with that viper engine is an 8.2L
Tis fair, I'd rather have a smaller capacity turbo'd quad cam V8 with better VE though, personally. Tickling along at part throttle in something of 8 litres displacement must cane the fuel That said the yanks have built their empire on big, cheap low tech engines..
