Mk2 1.8T Engine Brackets
Discussion in '1.8 & 1.8T' started by priceygti, Jun 26, 2011.
  1. priceygti Forum Member
    Shropshire
    I'd like to thank member vwd40 for confirming his setup for me.
    I am using a 20v engine with the standard 02J gearbox, along with MK2 Golf subframe and front engine carrier.
    I was finally able to get a full set of Corrado/Passat/G60 Engine Brackets with part numbers from my local Trade Parts Specialist.
    TPS still sell the G60 Brackets brand new and for around 45 each but it will save you a lot of hassle searching for them.
    Part Numbers
    Corrado/Passat/G60 Front Engine Bracket - 357199273
    Corrado/Passat/G60 Rear Engine Bracket - 535199354, 357199354, 357199354H or 535199354C
    Corrado/Passat/G60 Gearbox Mount - 357199353A
    Corrado G60 Gearbox Support Bracket - 357199356
    I hope this thread helps everyone else who's thinking of doing a 20VT swap or struggling with engine mounts
    Mark
  2. Mook
    Mook Forum Member
    South Coast
    Can a mod make this sticky please - so we don't keep getting asked the same question. Ta!
    Thanks for the post pricey :thumbup:
  3. vwd40 Forum Member
    Melbourne, Australia
    Agree Mook. Only thing to add is it's well worth Poly bushing the front crossmember too.
  4. priceygti Forum Member
    Shropshire
    I hope its of some use as the same question does pop up a lot. I will be polybushing the whole of my mk2 but thats a personal choice i guess.
    Mark
  5. JWYATT Forum Member
    South Coast
    Sweet info there !!!
    Cheers Jo ! :thumbup:
  6. priceygti Forum Member
    Shropshire
    bump for any upcoming questions relating to this
  7. Bushy B Forum Member
    We're just getting to point of installation having just removed and carefully labelled the wiring from the donor car.
    Notice your using the Diesel rear engine mount. Thought I'd read somewhere the G60 rear engine mount was favoured but I'm probably wrong.[:s].
    The G60 front engine bracket. Is that the whole thing that bolts to the front of the engine? The one we're working on at the moment is broken where the bottom bolt goes through.
  8. priceygti Forum Member
    Shropshire
    I have listed just the engine brackets i am using and what many others are using the mounts most people use G60 as there a good upgrade over the standard mk2 one's but without the price of vibratecnic's or similar after market mounts.
    HTH, Mark.
  9. rubjonny
    mk2 diesle uses same style mount as normal mk2, its the 16v/g60 rear mount you want, plus bonded rubber 1.3/late 16v box and front
  10. dubmonkey New Member
    Cardiff
    Would an ABF rear mount be the desirable style???
    Just bought an AGU, including Audi A3, for my mk2 shell and have the ABF mounts left over from my mk1 caddy build:lol:
  11. rubjonny
    only if you fit a mk3 golf subframe :)
  12. dubmonkey New Member
    Cardiff
    Balls, had one from the Toledo, sold it. Thanks for the quick response ;)
    Struggling with the widetrack decision - Widetrack means good brakes but rubbish wheel choice or std mk2 stuff which means great wheel choice but expensive to go over 280mm brakes[:s]
  13. rubjonny
    do you mean 4 or 5 stud? cos you can still go 4stud widetrack :p
    if you really want to keep 4 stud but use 5 stud bearign carriers and brakes, what you can do is press in 4 stud hubs and redrill 5stud brake discs to 4 :)
  14. dubmonkey New Member
    Cardiff
    Do the 4 stud hubs just fit then? I thought there was machining to do to make them fit??
    My plan was to go with mk2 caddy wheel bearing housings /hubs as they are the same as mk2 16V.
    Wayyyyyyyyyy off topic for this thread - should probably do my own build thread but I have my heart set on borbet As and preferably 9s up front - is this doable with widetrack???
    EDIT:: Found the widetrack FAQ:thumbup:
  15. rubjonny
    late spec mk2 and mk3 hubs fit 5 stud housings, just need to swap the outer cv if using 5 stud shafts or just use 4 stud mk3 ones. you need to go wide track with 5 stud bearing carriers though as the ball joint is further forward which will throw out the castor
  16. JWYATT Forum Member
    South Coast
    If I was to use the 357 199 273 front bracket and A o2j box , what starter would I use as the bracket above is m10 , but 20v starter is m12 bolts and not long enough too go through into that bracket ?
    / also I'll be running a g60 flywheel so I take it the 20v original starter can go into the ring gear ?
    Thanks ! :thumbup:
  17. priceygti Forum Member
    Shropshire
    i used the starter that the engine came with and got hold of some longer bolts from a local fastner company iirc they were 160xM10
    HTH Mark
  18. JWYATT Forum Member
    South Coast
    I was doing a clutch on a TDI the next day and found that the bolts were 165xm12 so I cut the nuts off the mk2 bracket welded some m12's on and that's sorted it now
    With m10 I found the starter could move/ adjusted a little until final torque ,
  19. Bushy B Forum Member
    Anybody know.. whats the difference between ?
    357 199 354 H
    and
    357 199 354 C As recommended
  20. rubjonny
