Seized Crank - Its Alive :-) !!!
Discussion in '1.8 & 1.8T' started by Richard Mk2, Apr 16, 2012.
  1. Richard Mk2
    London / Bucks
    Right then.
    To my dissapointment after putting so much work into my 1.8T setup, im 90% sure the crank has seized on me [8(]
    We have tried everything to free it, even towed it and tried to jump the engine, but the front wheels just lock up when put in gear.
    Is there any way of freeing up a seized engine ?
    Ive tried pouring oil down over the cams with the cam cover off, but it didn't free anything up ?
    Engine wont turn by hand either ?
    Could a dodgy gearbox cause this ? Then again we have towed it in neutral with no problems! It only locks when put in gear.
    Any help would be great.
    Cheers. Rich :thumbup:
  2. danster Forum Addict
    What bolts did you use to attach the clutch pressure plate? If you used the dual mass ones they will be too long and locking the crank to the block and main bearing cap.
  3. Richard Mk2
    London / Bucks
    I used the standard ones from the 8v engine Dan...
  4. sparrow Paid Member Paid Member
    Leamington Spa
    Can you drop the box off and see if there's anything obvious? Easier than taking the whole engine out.
  5. Richard Mk2
    London / Bucks
    Sounds like an idea Sparrow :thumbup:
    Im just awaiting my lock up garage door to be fixed, as my Mk2 is currently on the driveway.
    As soon as i get it back in there, i'll whip the gearbox off and see if anythings up, as all my tools are in my lockup!
    Is there anything else to look out for ?
  6. Collie Forum Junkie
    Adlington Lancs
    did the engine turn ok when out of car?
  7. danster Forum Addict
    Check the cam timing marks.
  8. danster Forum Addict
    And on that note another thing is the 4 crank pulley bolts. Did you have them off? It is possible for them to be too long and lock the crank by jamming on the oil seal casing.
  9. Richard Mk2
    London / Bucks
    Yea it was fine Collie. :thumbup:
    I set the timing when i fitted the new belts ect ect. This was a month before putting the engine and gearbox together.
    Since its been mated, the engine just wont turn over!
  10. Richard Mk2
    London / Bucks
    These bolts were not touched Dan. The engine came with a new timing belt, i just fitted the tensioners, water pump ect.
    It was turning freely as i set the timing :)
  11. lewp91 Forum Member
    Hertfordshire, United Kingdom
    sorry but i would deff, drop the box, and remove the clutch and fly wheel then try, if not, it may be time to take the engine apart :/
  12. mat-mk3
    mat-mk3 Administrator Admin
    Bristol
    Agree, I just cant see it being the engine. Drop the box and flywheel and check its ok.
    When you try to start it again, Take the fuel pump relay out and turn it over a few times to get the oil around it, Then pop the relay back in and fingers crossed:thumbup:
  13. Richard Mk2
    London / Bucks
    Thanks for the info :thumbup:
    As soon as i can get the MK2 back in my lock up (new door being fitted atm), i'll take the g-box off and see whats going on.
    As you said Mat, i doubt its the engine - hopefully!
    Will definitely crank it with the relay taken out.
    I'll update as soon as i can. Cheers :thumbup:
  14. rubjonny
    take the starter motor off and try turning engine by hand, also look at the flywheel see if there is anything odd there
  15. Matt82
    Matt82 Forum Addict
    GTI Scene
    after towing it id be suprised if something wasnt fubar now :(
  16. Richard Mk2
    London / Bucks
    Tried that too Jonny but no luck [8(]
    We only tried to jump it a couple of times while towing. Lets hope its something silly [8(]
  17. benthejettaman Forum Member
    some where in the uk
    does the lump turn backwards
  18. Richard Mk2
    London / Bucks
    No its stuck fast either way [8(]
  19. Rallye_Will Forum Member
    Devon
    I bet the clutch plate is in the wrong way round.
  20. Richard Mk2
    London / Bucks
    Im sure the clutch plate only goes on one way, as it has to line up with the 6 bolts and its metal gasket. Then fitted the rounded plate which is held in by the clip.
    Friction disc only goes on one way. I made sure this was centralised when bolting the flywheel to the clutch plate. I also made sure the friction disc fitted the spline on the gearbox before fitting it altogether.
    :thumbup:
