MK4 Central Locking Problems
Discussion in 'Mk4' started by Richard Mk2, Oct 4, 2013.
  1. Richard Mk2
    London / Bucks
    Right, I've got an annoying problem with my Mk4, which has got worse.
    A couple of years ago I installed a sub and amp into my Mk4. Once I was finished I went to lock the car via the key fob and nothing happened ?
    Thinking it was the key fob, I decided to use my spare key, which also didn't work, so I manually locked it.
    Next day, I unlocked the car via the key, and 10 secs later the alarm was sounding! You basically have 10 seconds to turn the ignition on to stop the alarm from sounding.
    I got used to it and didn't bother doing much about it for a while.
    Then a few months ago, the rear passenger side door will not open at all!! Its completely stuck shut ? The opener inside pulls towards you, but feels like its got some resistance and is holding back.
    I've also noticed that when I lock the door inside via the central locking button next to the electric window button , sometimes some of the doors wont open or lock ?
    Anyone else had similar problems ?
    And what could it be ?
    Cheers.
    Richard. :thumbup:
    Btw its not a fuse ;)
  2. MUSHY 16V
    aberdeen
    i just changed the door lock module on one of mine
    i'm 99% sure it that
  3. Richard Mk2
    London / Bucks
    :thumbup:
    Did you have trouble with your key fob and alarm then mushy ?
    What about my stuck door ?
    And would a dodgy convenience system cause this.
  4. MUSHY 16V
    aberdeen
    yes it would unlock ok but would not lock off the fob
  5. Richard Mk2
    London / Bucks
    See with mine none of the fobs work at all, and my alarm sounds after 10seconds if the ignition is not turned on ?
    I wonder if vag-com would flag up the error ?
    Its been like this for 2 years now, and now my rear door is stuck shut !!
  6. MUSHY 16V
    aberdeen
    mine started to do the door sticking locked or unlocked just before i changed it
    i knew it was the lock as the puddle light stayed on mine
  7. Richard Mk2
    London / Bucks
    Maybe this has gone as well as something else.
    Convenience system maybe ?
  8. Richard Mk2
    London / Bucks
    Would this fault come up on vagcom ?
  9. MUSHY 16V
    aberdeen
    mine never did with the door lock but it may convenience module
    you'v got a after market stero right bet it was after fitting it
    it started doing it
  10. Richard Mk2
    London / Bucks
    Yep. Is that a common issue with it effecting the locking ?
  11. MUSHY 16V
    aberdeen
    the boy i got my 4motion from got a polo for his son it only had the one key and the central locking didnt work and a few other thing we fixed
    i scan it for him and it came up with a faut for the convenience module we tested all the locks all ok
    i gave him a fip key to get cut so i could code it once he got it cut
    he also got a new fob he's a oem freek so the market stero got removed for a oem one
    central locking started working
    Richard Mk2 likes this.
  12. Richard Mk2
    London / Bucks
    Thanks for that Mushy :thumbup:
    I'll give that a go tomorrow and see what's happens :)
  13. MUSHY 16V
    aberdeen
    fingers crossed
    and if it is the stereo try work out why
    wonder if rj would know
