Electric water pumps
Discussion in 'Engines' started by HPR, Nov 2, 2013.
  1. HPR
    HPR Administrator Admin
    Today most car engines still use a mechanical waterpump, these run infact too slow at idle ( not enough cooling/ fluid flowing around) and too fast at high revs( too much liquid is pumped around ) and once the engine is switched off, no circulation at all
    Its were electric waterpump deliver an answer in supplying just as much as needed for the the conditions. Some car manufacturers made the switch to electric waterpump, these pumps would make an excelent choice .have a read
    http://www.omiq.it/resources/Documenti/DMDT_ATA_Ing_Auto_64_5_6_LR.pdf
    http://download.ms-motor-service.com/ximages/pg_50003963-02_web.pdf
    http://www.bimmerforums.com/forum/showthread.php?1956606-Electric-water-pumps
    http://www.mikrocontroller.net/attachment/118122/CWA200.pdf
    http://mbworld.org/forums/5620370-post24.html
    http://www.miataturbo.net/engine-performance-56/bmw-pierburg-electric-waterpump-controller-69420/
    - wired and run always at the same speed
    - speed control can be done with a stand alone controller as Tecomotive TinyCWA
    - By the ECU ( need a pwm output)
    Pierburg CWA 200 is 125 l/min @ 450mbar/6.5psi & 200watts. ( Used in BMW up to 272 PS )
    this pump is also used in motorsport by Peugeot S2000, Ford Fiesta S2000, and Mini John Cooper Works 1.6T WRC
    Pierburg CWA 400 is used in BMW`s with up to 340 PS
    BMW electric waterpump are made by Pierburg, Continental and VDO-Siemens
    Other electric pumps come from:
    http://www.meziere.com/displaycategory.aspx?id=244,336,352
    http://www.stewartcomponents.net/Me...OD&Product_Code=E558A&Category_Code=ElectPump
    http://www.dedenbear.com/TXTwp.htm#WP1n2
    all are still pricey...
  2. mono matt Forum Member
    So after all these years- well over 100 now, belt powered water pumps are to be frowned upon :-s
  3. TJ2727 Forum Member
    I suspect these are being used to help get some cars under a CO2 tax band etc
    That slight reduction in drive train drag and the ability to set the temp to the best level for CO2 reduction?
  4. Jon Olds Forum Junkie
    Ran a Davies Craig setup on the mk1 when they 1st came out. Repeated failures meant I eventually reverted back to mechanical. They have reduced the warranty period right down now, wonder why?
    Jon
    Full setup inc controller, new pump and all brackets could be for sale. Only if the person buying it came to see it first...
  5. HPR
    From the oem pumps we may expect them more durable, so these are maybe the way to go, rather than aftermarket pumps.
    Above post updated
  6. Tristan
    I asked about these before , as I see them (in small sizes) in the likes of MB Sprinters and LTs in work! And people seemed to think they weren't a goer. What does a typical belt driven pump flow?
  7. Jon Olds Forum Junkie
    My CDI water pump is conventional belt driven. (found the dratted leak down the front of the engine a while back)
    Jon
  8. infinity
    infinity Forum Member
    I had similar issues, but the internal seals are now ceramic and dont fail, i ve got a proper controller on it now, ie an electronic thermostat which controls its speed
  9. Toyotec
    More OEM production vehicles are heading this way, along with split systems.
    All FE driven but surely can have benefits for racers.
  10. Notso Swift Forum Member
    Ditto
    Post seal upgrade and I have never had an issue, mine is driven by the ECU, but basically runs flat out (target water temp is only 70dC)
  11. AjVR Forum Member
    Any idea on the amperage required to run these pump systems?
  12. Notso Swift Forum Member
    99% sure Mine is on a 10 amp fuse
  13. Jon Olds Forum Junkie
    After cooling is a great bonus. A simple timer relay will give you 30 seconds (or whatever) after shutdown. Especially good for turbo systems
    Jon
  14. HPR
  15. Nige
    Nige Paid Member Paid Member
    Has anyone experience of running an electric water pump alongside the OEM belt driven one to circulate the water after the engine has stopped?
    The vr6 has one from the factory. Are they plumbed in series with the mechanical pump or in a separate circuit?
  16. notenoughtime
    Essex
    The 225 bhp 1.8t engine also uses one
  17. Toyotec
    As does all 24v VR6 motors.
    The runaround pump is there to remove spots and is controlled by the fan controller on Mk4 and Mk3 platform cars.
  18. Nige
    Guys, thanks, I know other models run extra pumps. :thumbup:
    My question was regarding the plumbing of them.
    Are they in series with the standard mechanical pump?
  19. Brookster
    M1 J40
    get rid of the mechnical pump
    a friend of mine has made a blank plate for 16v pump which had a hose connection and uses a Davis Craig Electronic controlled pump ( Reversed the flow too ) ;)
    i'll get some photos
    16v 9a engine on Jenvey DTH etc 224bhp
  20. Nige
    To what benefit Rich? I'm not bothered about a few saved horsepower if there is any reduced reliability.
    Why not have both?
    Why reverse the flow surely Vw didn't just randomly pick the direction through the engine.
