ESP/ABS Warning light
Discussion in 'Mk5' started by trickrobo, Mar 10, 2014.
  1. trickrobo New Member
    Hi all, just had the dreaded ESP/ABS warning light come on and I was wondering is it just a case of cleaning the sensors as a first point of call as i have with cars in the past or is there anything else i can do to reset it. I've tried the ESP Button by the lighter etc with no joy. The warning light stays on all the time even after restarting the car.
    Thanks,
    Pete
  2. GVK
    Of course, it will need diagnostics carrying out to prove the fault.
    On these it's usually the brake pressure sensor which is part of the ABS module, it's a common fault on all Teves MK60 ABS equipped vehicles. (Ford,VW,BMW also have the same problem)
    You can get the module repaired by ECU repairers such as BBA reman.
    It's a very common problem, so you may even get lucky with goodwill at VW.
  3. trickrobo New Member
    Thanks for the reply, i'll try cleaning all the sensors then if no joy book it in at Awesome or something. Cheers,
    Pete
  4. MUSHY 16V
    aberdeen
    The ESP/ABS warning light can come on with a engine fault as well
    But you tend to have the engine light on as well but not always
    I don't think this is it in you case though as it tends to clear when you switch it on and off and come back after a few miles of driving
    As GVK said getting is scanned for the fault is the way forward
    Hope it's something simple :thumbup:
  5. GVK
    It could be an engine fault yeah, but 9/10 it's the brake pressure sensor in the module on these.
    MUSHY 16V likes this.
  6. MUSHY 16V
    aberdeen
    have a feeling your right
    I just like to look on the bright side not that it always pans out :cry:
    the fault i'v seen come up with the ABS when a engine fault has been loged is 01314
  7. trickrobo New Member
    Ok Guys you were right for future ref the fault code was 'G201 Brake pessure sensor 1'. VW have a repair kit for this for about 140 plus fitting now out so about 200 all in, from memory. Thanks again but as GVK says depending on the cars age and miles etc you might even get this on VW goodwill if you have a nice dealer near you.
  8. Hotgolf
    Smelly Cornelly
    They won't do it on good will, I've tried in the last couple of months.
    Let them fit it as even with Vcds its a b'stard to bleed!
  9. djk100uk New Member
    I had mine done for free last week, they had to get the ok from headquarters, I do have vwfsh and they did bleed my breaks last year as part of the service.
    08 Edition 30, 454k
  10. Danallkins
    Danallkins Forum Member
    Deal, Kent
    They will do this on goodwill. BBC watchdog got on to it. I had my wife's golf plus done in jan this year FOC! We never take it to them for a service and on a 55 plate at 150k !
    Tell them you heard about the watchdog investigation. Failing that contact vw UK... They will fix for free.
    We used EuroCanterbury VW... No hassle at all
    They even scanned it for free. They didn't make a single penny out of me.
  11. bmeskin New Member
  12. mr.brown
    Sunny Surrey
    Typo? or seriously 454k?
