ive got a 1300 mk2 polo, same engine as a golf as far as im aware theres an oil leak from a bolted on flange which i assume is the oil pump can i whip off the cam belt and pulleys then undo the oil pump and take it off?? i recon it needs a gasket anyone had one apart
as far as i can tell ..the flange of the oil pump where it bolts to the block seems to be leaking could also be that corner of the sump gaset or front crank oil seal i figured id change em all...but im unsure of what kind of job doing the oil pump gasket is
