might sound odd but does anyone know if there is a longer dipstick that will fit in the Agg dipstick tube? I am in the process of getting parts together to fit one in MY T25 crew cab, this involes using the T25 deisel [JX engine] sump and the usual practice is to fit the JX dipstick , but they never fit right as you have to cut down the AGG tube , drill it out to 8mm and jam the JX tube in ,
Do you mean longer in engine or the handle? Have seen handle that you cut original off and it grub screws on, or could you re-mark the dipstick, had to do that on an ital engine in Morris minor
I have one with a bit welded on in the current 1z engine thats in it . Just trying to find a neater solution i will get over to the scrap yard and see if i can find a longer one that i can trim to size
