As above, it dawned on me I need a clutch and pressure plate for my car. I've had HotGolf lighten a G60/abf f'wheel, what's the best clutch to drive an o2j from a mk4 1.8T? Estimated power no more than 150 bhp, road use primarily.
Hi Tris. You can run any of the 228mm clutches with that power tbh so mk3 16v/tdi/vr6, golf g60, corrado etc. Only turbo power dictates the use of a VR6 clutch as a minimum.
I can get LUK, SACHS and Valeo in the local motor factors, from 130 to 190 euro. No cheaper online. Are all of the 228 clutches 6 bolt?
Actually I've just realised I need the mounting bolts for the pressure plate ! Balls! Anyone know the part number?
Actually, on further reflection, will I need different bolts for the flywheel too? I used standard 18mm head ones same as what was on the 2.0 bottom end, with the hard stainless steel "washer" plate under the 6 of them.
Use ABF specific bolts Tris. No washer plate used. http://clubgti.com/showthread.php?223829-ABF-Flywheel-Bolts Flywheel Bolts x6 N90206103 https://www.ebay.co.uk/itm/vw-corrado-and-golf-g60-and-abf-16v-flywheel-bolt-set-/132463931653
