Won't that stop oil going through the filter when the engine is cold, with a remote mounted filter? Maybe I missed it, but I didn't see separate hoses for that. Or did you mean the bracket that the filter mounts to?
The Oil filter gets constant flow, the thermostat controls the flow rate through the 12 row cooler. I've been using this set up for the last 14 Yearsand works very well.
my first thought was like mikes. with two lines from the sandwich plates which i assume go to the remote filter, then the filter is thermostatically controlled to.
I have highlighted it for you, eurospec have there own website, but generally do business thro agents like Jabbasport. yes the do a 1.8 version
If you are changing the crank what else are you doing to the KR Block ? Re-bore ? personally i would fit an ABF or 9A Block
Brookster do not put the trigger wheel on the inside of the block, use an external one. I've heard of several exploding over time and mullering the inside of the engine.
Detailed on Page 1 of this thread http://www.clubgti.com/forum/showthread.php?t=186028 external trigger wheel fitted.
Update - FlyWheel Well just an Update the pistons should arrive today, the Flywheel just arrived from Hotgolf ! Excellent bit of work. New Modified Flywheel New Modified Flywheel on the Left and Standard on the right. Standard Flywheel Weight New flywheel weight big weight loss. SACHS Heavy Duty Pressure plate for the Helix Ceramic 4 PUK
^^ Mart is THE man. I must have a fetish for machined parts or summat - That looks lovely. I could roll about in pistons and cranks all day long.... Er...
A few more items have arrived also the Eurospeed gear. Dizzy Blank Plate Crank sensor brank, which will need to be spaced off a bit from the block.
