4 pin diesel tachometer wiring
Discussion in 'Electrical' started by Mattdriver, Oct 19, 2020.
  1. Mattdriver New Member
    I’ve got my self a 4 pin tacho from an early 1.6d and what to fit it to my 1.9d mk2. I know it needs + - and w terminals but don’t know about the 4th and don’t know what order. There wiring is completely independent of the rest of the clocks.
    what car did the cluster come from?
  3. Mattdriver New Member
    There both of a mk2 golf just the taco is of a early mk2 1.6d and the cluster I what to put it in is a 1991 petrol mk2's fitted with a 1y 1.9d from a mk3 golf.
    right I see so its literally the tacho taken out of a set of mk2 diesel clocks, might be tricky to track down what pin does what unfortunatly. do you have the original dash cluster it came from? if not may have to strip it apart and chase the 4 pins inside the circuit board and try and work it out that way
