4 Wire O2 sensor? Will it work?
Discussion in '8-valve' started by black_cabbie, May 25, 2004.
  1. black_cabbie Forum Member
    Belgium
    Gents,
    My O2 gave up last week.... It was only 2 months old! Thats what you get when you buy cheap ones!
    Anyway. I can get a new Bosch 4 wire sensor very cheap! Question is.... Will it work?
    Engine is Digifant and has a 3 wire O2 currently.
  2. fish18 Forum Member
    not absolutly sure but you will have to conect the heater and sensor -ve wires togeather (or just earth the heater -ve to the body work come to think of it), then it should work. they are usually heat proof wire and are an arse to solder tho!
  3. black_cabbie Forum Member
    Belgium
    So basically the extra fourth wire is the ground?
    Has anyone done it before?
  4. Crispy 8V CGTI Committee - Club Secretary Admin
    NW
    your better off getting a 3 wire bosch sensor suitable for your car, you'll have less problems ;)
  5. black_cabbie Forum Member
    Belgium
    Any idea where I can get one cheap?
  6. martyn_16v Forum Junkie
    behind the sofa
    Apparently VAG aren't too horrific for lambda probes
  7. TheSecondComing Forum Addict
    PM pigbladder - he got genuine ones from Ebay for cheap, will be able to give you the blokes name. But yes, the extra wire is a ground. One white wire is a switched positive for the heater, one white is a ground for the heater, grey wire is sensor ground and black wire is sensor signal.
  8. black_cabbie Forum Member
    Belgium
    thanks for the replies guys....
    Although I found a brand new Bosch 3 wire for 30 dollars shipped I will keep an eye for a cheap 4 wire one to hook up to the air/fuel gauge.
