ABF 16V NEED HELP. LOW POWER
Discussion in 'Engines' started by Matas Keršys, Sep 18, 2018.
  1. Matas Keršys New Member
    Hello guys, I'm new here, today I had my first run on a dyno with my first car, which is seat ibiza gti cupra 1998 16v 2.0L, dyno results came not so good, any ideas what I should be looking for? The car feels very unresponsive on low revs. [​IMG][​IMG]https://imgur.com/a/H7hYry0 thats a link to my dyno test results,
  2. GVK
    Getting full throttle?
    Cam timing check?
    Fault codes ?
  3. Matas Keršys New Member
    Still in need for a diagnostics, have no idea what has been done by previous owners.
  4. Matas Keršys New Member
    and on lower gears i can push throttle pedal to the max and just wait for the engine to do its thing on catching speed.
  5. Jon Olds Forum Junkie
    I would check valve timing and compression, the basics, but you know it makes sense.
    The rollers will have an AFR measurement, so you should a lack or excess of fuelling.
    Brakes aren't getting hot, are they? LOL
    Jon
  6. Matas Keršys New Member
    brakes are fine
