I'm after a bit of help from anyone who owns a ABF engine and VCDS. Could someone check the duty cycle % of the ISV at idle and then at increased RPM (say 3,000+ rpm) - does the duty cycle increase or decrease with RPM?
I believe you can only get this info from the later ECU's, measuring block group 3 (4th window) if that helps anyone.
