After a bit of research I have found that the Scirocco 16v/late cabby 100mm driveshafts have the same part numbers as MK2 Golf 100mm driveshafts. Now if it was this easy to upgrade to 100mm driveshafts on the MK1 platform why is it not more widely discussed? Have the latest driveshafts from VW changed slightly so they are suitable for both platforms? If they are the same then this will save me a considerable amount of money since some ebayers seem to think MK1 platform 100mm shafts are worth 100
Hmmm, this deffo needs discussing. As far as I know, the cabrio/Scirocco 100mm shafts are shorter than the Mk1 GTI shafts. But I wasn't aware (and struggle to believe) that Mk2 shafts are the same length as the Cabrio/Scirrocco 100s. People that put 16V boxes with 100mm flanges in GTIs on Mk1 shafts end up knocking CVs to bits, since those OEM Mk1 shafts are too long. That's all I know for now....
so nwhat am i going t do ith my 16v mk1 conversion ??? ur saying dont use mk1 shafts with 9a/kr box ?? use kr shafts ??
do people just replace the flanges on the box with the 16v 90mm ones then? Im just running an 8v box at the moment but been looking at 16v options
If you use 90mm output shafts, use Mk1 GTI shafts If you use 100mm output shafts, use late Cabrio/Scirocco shafts. The difference is caused (AFAIK) by the output shaft face sitting further out on the 100mm shafts.
I know thats what I thought, but check it out for yourself: left 191 407 271 K or FX right 191 407 274 GX the above are listed for both MK2 and MK1 cabby/Rocco.
The shafts are different lengths for mk1's, i've posted a pic before will see if i can find it, you can run into problems with the 100mm outers binding in the hubs too.There has been a few threads on it.
maybe the later hubs are different and make up for the extra length, the above part numbers are for the complete driveshaft including both c/vs inner & outer. Or the shaft design is different...
Mk1 shafts gti vs cabby http://www.clubgti.co.uk/forum/showthread.php?t=43985 hubs locking up http://www.clubgti.co.uk/forum/showthread.php?t=136806
Rupe - great pic, just what was needed By chance can you give the bare shafts a measure from tip to tip and help with the driveshaft FAQ here? Cheers if you can. It's either the driveflange face sitting further out on a 100mm 020 'box, or possibly also the actual length of the inner CV unit itself and the distance from the inner cv-bolt up flange to the circlip groove. Thinking about it though, the circlip groove is dictated by the shaft, so that means it's the output flange.
Those shafts aren't bare anymore, but gillm measured some rocco shafts from http://www.clubgti.co.uk/forum/showthread.php?t=148331 their is also mention of outer cv's being different lengths in that thread too.
Comparing a 100mm and a 90mm (new style 90mm for the springs and cones, like the 100mm), the 90mm is shorter The 90mm flange is about 53mm from the face where the CV mounts to the end of the flange where the spring slides on. The 100mm flange is about 61mm. There is about an 8mm difference between the 90mm and 100mm flanges. Brian
you can mod the the mk1 shaft to take the 100mm cv,just needs a few mm turned of to allow you to fit the circlip.
Confirms The 100mm flange on the 020 sticks out further than the 90mm flange. About 8mm or so further on each side. Brian
This thread is about 100mm shafts on a MK1 platform being the same as 100mm shafts on a MK2 platform, not 90 vs 100mm
Ah I think it was me that fired us OT But in a roundabout way, aren't we getting to an answer! We know the 020 'box width doesn't change when it has 100mm outputs on it - be it inside a Mk1 or Mk2. So without changing anything else, this suggests that either a Mk1 has the same overall track width as a Mk2 < no!> or that the shafts are different, or that the outer CVs on a Mk2 are wider (which IIRC, they're not), or that the Mk2 hub design creates a wider track . > forwards!
