any active members into mega/microsquirt?
Discussion in 'Throttle bodies & non-OEM ECUs' started by pigbladder, Nov 22, 2019.
  1. pigbladder Forum Addict
    cambridge , uk
    ive got a mk2 polo gt (3f) that no one can get running right , im considering microsquirting it vs throwing more money at parts
    wondered if theres any members into it that could talk things over with me
    orig system has an AFM with temp sender
    am i along the right lines thinking-
    wedge afm open and use its inlet air temp sensor /or straight pipe and scrap yard sensor
    use current fuel pump relay
    use dizzy hall sender to give a signal
    use current coolant temp sender
    use current coil and tci
    use current tps
    then once wired i can get ign map based on my spec
    where do i get the basic start up fueling from?
    then ride around with wideband and let it self tune ?
    its just a fairly basic spec car , not planning to be a race car etc
    any ideas /input please
  2. pigbladder Forum Addict
    cambridge , uk
    bump any members i can chat with please
    ordered a microsquirt today and sure i will have questions
  3. Toyotec
    Been a long time since I built those!
  4. pigbladder Forum Addict
    cambridge , uk
    this one is factory built so takes away a bit of risk
    basicly need to copy your 8v thread but translate to polo , might need a few pointers on wiring
    did you map that with the wideband then just run it off the map with no o2 input ?
  5. Toyotec
    Takes away the risk from joe bloggs.
    "wideband" feedback came after.
    Bearing in mind I have been tuning engines, before EFI, most cars were mapped open loop as you would on a dyno, but with independant lambda measurement, feeding back to determine if you got the exhaust mixture where you desired it.
    pigbladder likes this.
  6. pigbladder Forum Addict
    cambridge , uk
    toyo does the vw dizzys need a pull up resistor ? getting mixed advice
    its the 3f engine same as a g40 /py dizzy
  7. Toyotec
    I still use the dizzy hall in the WOLF R.
    Been a while since I looked in that ECU though. I do it still runs.
  8. pigbladder Forum Addict
    cambridge , uk
    dont suppose you know the values for these toyo> or are they in the tunerstudio already
  9. Toyotec
  10. pigbladder Forum Addict
    cambridge , uk
    perfect
    just going through tunerstudio ticking off the boxes /options ...unsure of these with the mk2 coil /tci
    fuel inj dead time /batt voltage correction?
    cranking dwell,dwell type, nominal dwell,spark duration
    any ideas please
  11. Toyotec
    I will have to look a MK2 8v calibration to answer the above.
    Can do so this evening.
  12. Toyotec
    For the Digifant TCI-h it is fixed dwell.
    Spark duration not sure what you mean.
    Injector opening time 1.0 secs to start with
    Batt/volt correction 0.2 ms.v
  13. pigbladder Forum Addict
    cambridge , uk
    is this easier ...spark duration shown here on the right , also what do i put in the trigger angle offset ?
  14. 2swe Forum Member
    Czech Republic
    spark duration is time required for the spark to complete, after this time period the coil can be charged for the next spark. you can leave it at 1ms default.
    trigger angle offset is crank position before TDC where the ecu receives signal from hall sender.
  15. Toyotec
    8V yes?
    So a dizzy with plug leads yes?
  16. pigbladder Forum Addict
    cambridge , uk
    toyo yes
    8v digi polo with mk2 style coil and tci...basicly same as your old 8v golf but its a polo /1400
    stock dizzy , tci , inj , coolant sensors and this one had a factory tps...delete afm , running off orig relays and will have wideband
    thanks all
  17. Toyotec
    If like one of my old cars, then use the settings I gave as going in points. It will fire up.
  18. pigbladder Forum Addict
    cambridge , uk
    decided to add a map sensor , will plumb that in and report back
    thanks so far
    Toyotec likes this.
  19. pigbladder Forum Addict
    cambridge , uk
    so what ? set it what base timing was on the stock car ?
    thanks again
  20. Toyotec
    That is an offset for the trigger. Like globally moving a dizzy.
