Brake issue
Discussion in 'Mk5' started by nme motorsport, Jul 12, 2017.
  1. nme motorsport Forum Member
    The car went for its mot and failed on the rearbrake binding so I tried winding the piston in and it was solid so I clamped the rear flexible pipe and replaced the calliper with minimal fluid loss
    After replacing the calliper I bled the bake brake I now have a pedal the slowly sinks to the floor when pressed
    Any help would be great
    Many thanks Neil
  2. pigbladder Forum Addict
    cambridge , uk
    bleed it again...did you clamp the compensator valve open?
