Centre consol
Discussion in 'Mk2' started by Matt Golf, Jan 22, 2021.
  1. Matt Golf Forum Member
    Kent
    My centre consol is for a 5 door with ful electric windows (with the five switches across the middle). Its pretty battered though. You can get brand new the ones with no window switches at all. Has anyone managed to get the one with no switch panels to be converted to hold standard vw window switches or is not possible?
  2. Savagesam
    Yes you can, I 3D printed this for one with no panels for the window switches. You can buy. VW ones also.
  3. Matt Golf Forum Member
    Kent
    Cheers, so you can buy a switch panel from VW?
    Presume I have to cut off the little oddments cubby hole so that the switch panel fits?
  4. Savagesam
    No, you drill two holes in the back and it bolts in.
    Apparently so, I’ve never seen on. Which is why I printed it. That I need it, I’ve got a proper one
  5. Matt Golf Forum Member
    Kent
    Cheers, thats really helpful.
  6. valvemiester
    Trowbridge
    My C reg 3 door 8v gti has that switch panel in it fitted from new as stated just two holes drilled into the centre console cubby hole.
  7. Matt Golf Forum Member
    Kent
    I wonder what the part number is? Ive never seen it and I have owned my Mk2 since 1997.
  8. rubjonny
    the removable switch panel is aftermarket only, the genuine consoles have the switch panel moulded into it
