GSF have a great range of promotions on this Christmas! On top of the offers posted below, i will add a discount code to this thread every day until 20/12/2016. UNITLITE USB RECHARGEABLE BEANIE HAT 21.95 150lumens, 300MA lithium-polymer battery, 3 light settings, approx 4 hour battery life per charge. UNILITE PS-IL3R USB INSPECTION LIGHT 19.99 Samsung SMD provide 300lmens of power for close inspection work and a 100lumen torch function with focus beam. 360degree magnetic hanging hook. Rechargeable via USB cable. SEALEY PORTABLE TOOL CHEST & 72PC TOOL KIT 115.00 3 drawer tool chest with ball bearing runners (Red/GreyOverall Size (W x D x H): 510 x 225 x 300mm) LED022 - 36LED + 0.5W LED Stick Light - Pliers Set 3pc - Adjustable Wrench 150mm - Hex Key Set 25pc - Hacksaw 300mm - Soft Grip Screwdriver Set 6pc - Combination Spanner Set 11pc Metric - Socket & Bit Set 24pc 1/4"Sq Drive Metric SEALEY 20in1 SCREW DRIVER SET 11.99 Two position driver handle can be used as standard screwdriver or t-handle, features soft grip and lifetime warranty. SEALEY TOOL BOX WITH TOTE TRAY 16.99 Tough composite construction, comfort grip carry handle, two flip lid organisers, tote tray, tough clasps with padlock facility HEX KEY SET 10PC T-HANDLE 13.00 Chrome vanadium steel, includes wall mountable organiser. 8PC HI-VIS SCREWDRIVER SET 10.50 Magnetized tips, ergonomically shaped handles and a hanging hole for storage SEALEY 37PC 1/4 & 3/8SQ DRIVE SOCKET SET 23.50 Carbon steel sockets and accessories, supplied in carry case and includes lifetime warranty. SEALEY COMBINATION SPANNER SET 18PC 24.95 Drop forged chrome vanadium spanners, open end and 12point wall drive ring, supplied in carry rack. Includes lifetime warranty! SEALEY 12PC METRIC COMBI SPANNER SET 14.99 12PC drop forged chrome vanadium spanners, open end and wall drive. VETECH WASHABLE SEAT COVER 10.00
Today is the last day of 48% off car parts, grab a bargain or some winter cleaning goods!!! Discount code : HENS
Hi mate. I need a MK2 Power Steering rack but see you stock 2 different types and im not sure which one I need. Been trying to find out so I can use a code and order but have had no luck. Maybe you can help. Its a 91 plate (H reg) 8v GTI. Many thanks,
We list two PAS racks, the only way to define them is by number of teeth! One is 22 the other 36. I do believe it was mostly the 16V GTi that was fitted with the 22 tooth version. I would suggest checking the rack if possible, or the OE number stamped on it! We are happy to sort the discount out for you regardless of when you order. Thanks
