Correct routing of PAS pipes
Discussion in 'Mk2' started by Matt Golf, Feb 23, 2021.
  1. Matt Golf Forum Member
    Kent
    Do these go under the front engine mount or over the top of the front engine mount?
    Cheers
  2. costel1969
    Rightly (or wrongly) on my Mk2, they are going over the engine mount and they are covered in a plastic outer coating to prevent wear due to movement/vibration.
  3. davidut5 Forum Member
    Romania
    yes they go underneath. there is a very high tech bracket to hold the pipes, you have a flat bit of steel bent into a J shape bolted to the front of the block. You then chuck the pipes into it :lol:
    heres a piccy of it, might have to go to a specialist engineering shop to reproduce and make sure you spec the highest quality steel:
  5. rubjonny
    for the mk3 golf there is a bracket bolted to a stud on the end of the lower starter motor bolt to hold up the pressure line, the return has a metal pipe bolted to the front carrier
  6. valvemiester
    Trowbridge
    My mk2 16v is the same as RJ's
