cutting out - Gti 16v KR
Discussion in 'Mk2' started by Southside, Aug 26, 2022.
  1. Southside Paid Member Paid Member
    Oh btw, checked the injectors and mine do have the top hat. You think it worth giving them a clean?
  2. watercooled Forum Member
    Nelson,New Zealand
    Sort the air leak first,cheers
    Southside likes this.
  3. Southside Paid Member Paid Member
    This is driving me nuts now
    So I clamped the sawn off bolt in that rubber pipe and I'm still not able to adjust the idling. I checked the injector plastic inserts and they look like they've been replaced but the rubber washer was missing. Could that be it?
  5. Southside Paid Member Paid Member
  6. Southside Paid Member Paid Member
    So new seals in and I also sorted out the wiring for the WUR, coolant temp and 5th injector but no difference with the idling with the bolt and clamp still in place :(
    Still same issue driving the car, every time I came to a stop, car turns off. Starts up though
  7. Southside Paid Member Paid Member
  8. rubjonny
    the originals are square but round ones should work too I guess once nipped up? maybe confirm with seller to make sure they're correct
  9. Southside Paid Member Paid Member
    Mark from Classic VW confirmed that these are the right ones.
    Where do I go from here?
  10. rubjonny
    ok they should work then, once squished in there they'll go to the right shape
  11. Southside Paid Member Paid Member
    Just looking at the diagram on the Classic VW site and these seem like they fit between the brass and plastic inserts? I've installed them on the plastic inserts ends
  12. Southside Paid Member Paid Member
    Should have 2 according to this? So I'm missing another one as well?
  13. rubjonny
    the diagram isnt very clear (not their fault, its the same one in ETKA :lol:) the seal goes between the plastic insert and the inlet, you slip it up the plastic snug, fit plastic insert to the brass bit then screw them in.
    the lower injector seal in that piccy is the one on the 'top hat'
  14. Southside Paid Member Paid Member
    that's how I fitted it!
  15. Matt Golf Forum Member
    Kent
    And me!
  16. rubjonny
    ok, so before you said pinching the vac tube lowered the idle, does it still do that?
  17. Southside Paid Member Paid Member
    FIXED IT.
    Bloody cut off valve!!! Disconnected it and the car runs perfectly.
    Thanks again for all your help and advice chaps
  18. costel1969
    Great stuff - what is the cutoff valve, I'm not familiar with that and it's years since I worked on a KR so forgive my ignorance.
    More importantly does my stupid 8V have one and is it potentially the cause of my woes?
  19. rubjonny
    its the black plastic thing behind the airbox, catches revs if you lift off at high rpm. if they go faulty can cause the engine to just die
    8v doesnt have one so keep looking ;)
  20. costel1969
    Dammit RJ, you got me right in the love spuds with that one....
