Yep, same findings here - KR has 5mm more oil on the stick. Thread summary: Engine Dipstick part no Dipstick measuring point (ABF/9A is ref) Dipstick tube length Plastic collar part no Plastic collar position (Petrol is ref) Net effect on oil level 1Z 028 115 611 C ~10mm more oil 182mm 028 103 663 3mm taller ~15mm less KR 027 115 611 B 5mm more oil 209mm* 058 103 663 (Formerly 049 103 663) n/a - datum ~5mm more 9A/ABF 051 115 611 B (late?) n/a - datum ? 058 103 663 n/a - datum n/a - datum 9A/ABF 051 115 611 (early) n/a - datum ? 058 103 663 n/a - datum n/a - datum EZ (8v carb) assume KR no data 211mm* 058 103 663 (Formerly 049 103 663) Assume KR stick so 5mm less * Treat as the same Note: ABF is 16mm taller in the block, but the oil level is around the same position as the short blocks. ABF oil pump picks up in sump from 5mm below standard 8v/KR position
Any info on dipsticks/Tubes on the transverse 1.8T I have part numbers and they seem to be the same regardless of inlet side. Dipstick is 06A 115 611 Q, Guide Funnel is 06A 103 663 B Are they interchangable on the older engines? Or should i say are the metal Guide tubes the same diameter?
Does anybody how much the abf dipstick protrudes from the steel holder tube that goes into the block? I have shortened the steel tube but did not take an accurate enough measurement this means im now unsure of how much to take of the dipstick it self!!
easiest way forward is measure the tube from a mk1/2/3 1.6-1.8 lump, just make sure if its from a mk1 its later block with plastic guide tube like yours then compare to your shortened version
