The whole body is wobbling when running. Is it likely to be the distributor or a problem with the block hole it fits into oval? Cap is cable tied on for some reason Runs OK
Probably need to pull it out and take a look, I take it the clamp is fitted and tight? There is an o'ring round the base 026905261 available here which might help: https://www.classic-vw.co.uk/distributor-seal-026905261-golf-jetta-scirocco-corrado-16217-p.asp
Thanks Rj will order and pull it out in one go to inspect with the o ring at the ready. I've never seen a distributor wobbling before
