So, as I was not able to find much info until G60Dub mentioned it, I'm creating the little DIY. From: VW 5 Speed 02J Transmission Problems: http://www.vwtransaxles.com/diff.html Cross Shaft Roll Pin Breaks & Cross Shaft Punctures Case-This is the most common failure for all o2j rebuilds that come into our shop. There is a single 5 MM roll pin retaining the cross shaft. We double roll pin the shaft with an SAE type pin inside the metric pin. Next we grind a small "V" groove between the cross shaft and differential. Then a small root weld is applied. We haven't had a roll pin failure since using these procedures. So, because of this: I got this: Decided to reinforce the pin. Basically, just insert an extra pin inside the existing one, or remove the existing one, and insert a stronger one. Cross shaft, broken roll pin, & replacement double roll pins I hope that this will be the last issue with the gearbox
