Ed35 engine problems
Discussion in 'Mk6' started by Golf gti ed35, Sep 7, 2016.
  1. Golf gti ed35 New Member
    Liverpool
    Hi all, with the ed35 running the ea 113 high output engine format, is there any known issues i need to be aware off. Any owners out there who could share any knowledge of how to avoid common problems. Thanks
  2. beetie
    beetie Forum Member
    leicester
    It's the same engine as in the ed30. Loads of info on mk5forum.
    Main ones are just serviceable items, such as, fuel cam follower, diverter valve leaking boost, intercooler hose seal leaking boost, thermostat getting lazy and the car then taking ages to warm up, and keep up with the cam belt service intervals.
  3. Golf gti ed35 New Member
    Liverpool
    Thanks apreciate it .
  4. Golf gti ed35 New Member
    Liverpool
    Hi all, i think i may have a slight problem with my golf. As i slightly depress the throttle theres a slight creaking sound coming from underneath the car sounds like drivers side, any gear from low revs.also as the boost builds just before you hit it, theres a loud whistling sound as u come on to power.
    I cant work out if its a leak or the turbo spinning up .
    Power seems good and no loss of drivability.
    Anyone had something similar. Advice would be brill thankyou.
