Embarking on a BAM in a Mk2
Discussion in '1.8 & 1.8T' started by foxyjay, Sep 14, 2011.
  1. mk2bal Forum Member
    I'd say by a couple of pages into this thread you were commited past the point if no return. It's economically (and physically) ridiculous to turn back now.. If you'd have pulled your finger out you'd be reaping the fruits of your labour already. I know this because I used to read your thread when doing my loom etc. It's been in and enjoyed for nearly a year now!!! Pleeeeeease finish it ffs! Even if you only do a thousand miles in it then sell it like some do!?!?
  2. JeffreyMk2 New Member
    Hello, sorry for bumping this topic up.
    but what rear gearbox bracket did you use?
    i have an 02r gvz gearbox but don't know what bracket to use...
    jeffrey
  3. rubjonny
    think it would be same as 02a/j, if so would need 02a type bracket 357199353A
  4. JeffreyMk2 New Member
    Hello,
    That is what i also thought, but 02a/j has 3 holes to Bold in, and 02r only has 2. The top 1 and middle 1.
    So i would miss the bottom one
    Jeffrey
  5. rubjonny
    ah so its similar to 02S casing then, you can make a simple bracket picking up from nearby bolt holes to get it securely fitted :)
  6. JeffreyMk2 New Member
    So there is no oem part i can use?
    jeffrey
  7. rubjonny
    only 100% oem way is change the casing over for 02a/j so it has all the holes, otherwise just make yourself a little bracket :)
  8. JeffreyMk2 New Member
    Ah ok, i prefer not to make them my self. But i want to stick to this gearbox so i Will make something to work.
    thanks for your help!
  9. dodgy
    Not sure if any help, when I was looking at 6 speed mounts, Darkside development had 2 types listed, one was mk4 o2m, which is the usual, but they also had another type which was using the polo/fabia/ibiza box, but I'm unsure of codes of them, it's not the cheapest option.
    I had leon box so mk4 style.
