Engine Identification - 1.8 8v TSR?
Discussion in '8-valve' started by peej, Jul 9, 2019.
  1. peej New Member
    Evening all, I’ve had this sitting in a corner of the garage for a few years now but finally popped it on the engine stand now the ABF is in my MK2.
    Part number on the block: 026103021B
    Pistons: 82.485
    It’s got a TSR Number written on it but also a PB number. I got it with a Schrick 01401 76000 cam and a head with G M Sport stamped on it and T Betts stamped below that (also date stamped 03/98).
    Head Part Number: 026 103 373F
    So.......where can I find out more about these parts? Worth rebuilding? Is this a ‘set’ or just a random collection of parts that may not work together?
    Thanks in advance!
    Pete.
    Sounds like a mix and match? My TSR has TSR head stamped on the end, and a serial number. same for the block.
    The TSR cams are usually stamped TSR 203 or similar on the end iirc.
  3. Tristan
    Also, if it's a 1.8 block with those pistons, it's been extensively overbored to make a 1.9.
    Which is pretty sweet.
    peej likes this.
  4. peej New Member
    Thanks Tristan, the cam def. isn’t TSR then, head is a little more confusing. I’ll get some pics uploaded, that might help.
    Thanks for your help so far!
  5. drunkenalan Paid Member Paid Member
    Leicester
    My TSR 1900 has 83mm pistons in.
    Could it be a bubble block 3a? I don’t know blocks by vw codes, as they had a habit of mixing them.
    peej likes this.
