extra power for 2.0 16v 1993 corrado
Discussion in 'Corrado' started by dave weatherall, Dec 7, 2014.
  1. dave weatherall New Member
    engine is in great condition and I was wondering how much extra power I will get from the following:
    1. k and n panel filter in drilled airbox with 2 3inch ram pipes direct from outer wing into airbox
    2. stainless steel 4 branch manifold
    3. jetex cat bypass pipe
    4. scorpion stainless exhaust system
    5. always running on super unleaded
    thanks.
  2. Trev16v
    Oxfordshireland
    Hi Dave,
    Not a direct answer to your question, but unless you've already done it, using a KR inlet camshaft is known to be a good upgrade on the 9A engine.
  3. odub Forum Member
    Colchester, Essex
    I can't comment on everything but I was running kr cams, air feed into the air box, jetex exhaust with all of the silencers, milltek decat, k and n panel filter and was at 157 bhp on some very honest rollers. I fitted the decat after the other mods and gained 8 bhp alone
