Golf Mk1 KR16V swap
Discussion in 'Say 'hello' in here.' started by Theo76wbk, Oct 15, 2020.
  1. Theo76wbk New Member
    Hi ,new on this forum , i'm Theo from Romania
    After some years of wanting one , i finally got my mk1 76' coupe golf
    After changing the wheels , put in a nice Recaro interior , i wanted to get a more reliable and more powerfull engine , to take out her origial 70k km 1.1 engine
    After some research, i bought a 16v 1.8 KR engine from a Scirrocco Mk2
    I have some basic questions about the swap so :
    What axles do i need to get to fit ? i know the kr ones are 100mm
    Do i need to cut or weld the engine mounts
    Thanks
    I take all advices ; tips and tricks
    thanks boys
    Here a pic of my walletbreaker
  2. 2swe Forum Member
    Czech Republic
    scirocco or cabrio axles with 100 mm inner cv joints will fit.
    you have to cut and weld the right hand side mount (close to timing belt), other three are ok.
  3. Theo76wbk New Member
    The scirocco ones are the same at lenght ?
  4. 2swe Forum Member
    Czech Republic
    yes, both scirocco mk1 an 2 share the same platform as mk1 golf.
  5. rubjonny
    1. depends on the chosen gearbox. post-84 mk1 cab/rocco gti and mk2 use 100mm, so need the post-84 cab/rocco shafts to match. if you fget a tintop gti box these are 90mm, so can use 90mm 1.5-1.8 mk1 shafts. can also convert the box between 90 and 100mm, so long as you get the right flanges to suit box as early and late differ:
    http://brokevw.com/020flange.html
    http://brokevw.com/flanges.html
    2. yep, can use the old one once removed flip it the other way and weld to 1.5-1.8 position, but need to add some extra steel to fill a gap or weld later bracket. some pics for reference and other bits n bobs you may find useful:
    https://www.clubgti.com/forums/inde...mk1-cabby-several-years-in-the-making.186766/
    you also need to change your steering rack if going 020 box, since 1.0-1.3 and auto ones dont have one of the brackets on it needed for linkages to bolt to
