Having a nightmare mk3 agg 8v gti will not start
Discussion in 'Engines' started by donnyrayvon, Mar 9, 2018.
  1. donnyrayvon New Member
    ripley Derbyshire
    Need help please I'm at breaking point, car will not start at all. So far had new coil, on my second cam sensor, got spark when testing ht lead to block, gad a new ecu relay and still nothing at all, been looking at it for a month now,first time it broke down called AA he gave battery a quick charge and it started, next day ran for about a mile and cut out, AA again, wouldn't go so tow to garage, and you guessed it, started straight away, but then cut out hence gad the coil, relay and then the cam sensor changed and ran as it should for a week, cam out in the morning and nothing and nothing since even with another cam sensor fitted, can anyone please help me it's driving me mad now, no vag com so can't really see if it has faults
    AGG... Cam sensor? I presume you mean Crank Sensor?
    Have you checked the fuelling?
  3. donnyrayvon New Member
    ripley Derbyshire
    Yer sorry crank sensor, fuel will be next check have read I can test relay by take number 18 and putting it where fuel pump relay should ve am I correct
  4. Tristan
    I'd be checking the fuel pressure.
  5. GVK
    Check you have battery voltage on fuse 15, could have a bad ignition switch if not.
  6. Jon Olds Forum Junkie
    Easy start, if it doesn't fire, its electrical (assuming its got compression and the valve timing is ok)
    Jon
  7. donnyrayvon New Member
    ripley Derbyshire
    Thanks all so far.
    How do I check fuel pressure
    Checking fuse 15 is that with ignition switched on
    Took plugs out they smell of fuel but didn't seem to be wet
  8. GVK
    Check across the battery first, say you have 12.5v there then check fuse 15 with key on.
    Fuel pressure check will need a gauge.
