I have changed the header tank on my 8v Gti to the later round one. I would like to use the correct connector for the built in sensor. Does anyone have the part No? I tried ETKA but they have mixed things up on their site with the fuel tank sender! Many thanks
heyup, its 357972753. this one is a 3 pin but it still fits fine, and has superceeded the original funny 2 pin connector. if it has to be the prop;er plug mk3 golf, 6n polo, ibiza, caddy etc 90-99ish will all have same plug
original plug is 357906752, couple on ebay but a bit pricey. ask around on the classifieds and FB groups,. someone will have one for you. Brendon Moss and Matthew Palmer break mk2s so should be able to sort you
Brilliant! Thanks John, I have ordered this one 357 972 753 3-WAY CONNECTOR KIT Inc Terminals and Seals [3-AC080] 357972753 JPT | eBay I will let you know how it goes.
perfect, all you need is a seal blank for the middle hole or you can use a normal wire seal with a little smear of silicone to fill the wire hole
