How to ...Fitting Focus/Seat Short master cylinder to mk2 servo modification for 1.8t
Discussion in 'Chassis' started by fasteddie, Sep 5, 2014.
  1. fasteddie
    fasteddie Banned
    Tis odd that [:[]
    So just for you I went and checked what the craic was :thumbup:
    factory 16v mk2 golf master cylinder 22mm and cupra R same as focus 24mm
    Wee note need new batteries [!]
    The same ;)
    Standard one on the inside
    47mm
    cupra/focus
    44mm
    hence you need to remove the spud and file it by 3mm :thumbup:
    The follow up to above
    Just for you mate :thumbup:
    Standard Mk2 golf Servo
    The Spud in the center
    Wee pair of pliers ..grab da sucker and pull
    And here it is :) ( Wee note some have a shim or two, Washers are shims ... look for these once you pull spud out )
    Now stick da sucker in a drill
    spin on file to remove 3mm..... KEEP THAT SHAPE ;)
    Measure before and as you go ...you can take it off but can't put it back on
    I HOPE THIS IS CLEAR ENOUGH [:[][:[][:-B]:thumbup:
    Maybe pin it to help members :thumbup:
    Ari, Funkmaster, Nige and 4 others like this.
  2. Sirguydo
    Bolton
    Glad it's mk2 servo and not bits of work on the poopolol
    fasteddie likes this.
  3. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    How about just drilling the focus mcyl by 3mm ?? Is there enough material there to do this I wonder ..
  4. fasteddie
    fasteddie Banned
    [:s]lol
  5. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    Surely the master cyl has plenty of metal to accommodate the 3mm required?
  6. Sirguydo
    Bolton
    I'd say it's a lot easier to file 3mm of the spud than drill a neat accurate hole 3mm deeper [:s]
    Nige and fasteddie like this.
  7. fasteddie
    fasteddie Banned
    Are you asking or telling ..no answer required
    I look at a problem and I look at ways I think is best to sort it, its what I do
    If you're good at what you do, you get on and do it you don't explain yourself ;)
    What you see above is the best way to go about this.... hope this helps you :thumbup:
  8. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    Now I'm even more confused
  9. Sirguydo
    Bolton
    Eddie thinks his way does the job very well lol so why do it any other way ?
    Don't think you need to take the mc off to get the spud out ???
  10. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    I just don't want to take the servo out again
    Now that was a pain In the ar5e to get back In
  11. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    Eddie, what reservoir do you have on that focus one ?
    Is it the seat version ?
  12. fasteddie
    fasteddie Banned
    The short one you see is A Seat Ibiza Cupra one with its reservoir
    The focus one you can use the mk2 reservoir, just change the seals over to suit and file/remove the center divider
    making sure to plug/seal master cylinder ports ;)
    Look at post 103 you will see I use the focus one on my car
    Click on link below ..you can see both master cylinders
    http://www.clubgti.com/showthread.php?269742-My-Red-MK2-Golf-GTI-20v-Rebuild/page5
  13. fasteddie
    fasteddie Banned
    You can remove the spud with servo still in place :thumbup:
  14. slimwadey Paid Member Paid Member
    Thatcham Berkshire.
    Sweet, just need to buy a master now
  15. Lincs golfer New Member
    Don't linch me for this but what is the gain to this mod as there don't look much in the size of things to warrant it
  16. fasteddie
    fasteddie Banned
    You need to be clearer, Warrant what ? the gain is you can run the master cylinder as it should be fitted factory without the use of a spacer and an additional makeshift seal
    This master cylinder will not work without the 3mm adjustment [xx(]
    Its about doing the thing right :thumbup:
    Hope this helps you :)
    Nige likes this.
  17. Nige
    Nige Paid Member Paid Member
    If you have posts per page different to the forum default, that doesn`t work. Better to link to the actual post :thumbup:
    ie MC In the car and on the Servo
    What do you mean about the divider / seal ?
    I hadn`t seen this done before, great mod and thanks for sharing :clap:
  18. Sirguydo
    Bolton
    Nige :thumbup: flippin clever clogs lol
  19. Lincs golfer New Member
    what i ment was what is the need for this over a standard mk2 setup?
    as im hopeing to keep my brake setup as is on the golf im doing as it was effective enough for racing but im changeing the engine to an agu
  20. fasteddie
    fasteddie Banned
    No need at all for this mate ;) If yours is effective enough for racing :)
    But if you did want to fit one, this is how you would go about it [:-B]
    Lincs golfer and Nige like this.
