Hi, Has any member fitted LED bulbs to the indicators on a Mk1. Tried ‘Ring’ 21w standard bulbs but they do not work. Fit one and that and the normal filament bulb do flash but faster than usual. Fit two and they simply glow and do not flash at all. Not a major issue. Just thought I would upgrade.
Thanks. I thought that may be the case. Do you happen to know on the Mk1 should both the reversing lights operate. On mine only The nearside one lights up? Same with the high density red fog. One side or two Thanks
yep need special relay, or resistors tapped to the wiring to simulate the load of a 21w bulb should have 2 reversing lights, 1 fog light
