Irwin bolt grippers
Discussion in 'Tools, Equipment & Fasteners' started by Hodder, Mar 14, 2008.
  1. Hodder New Member
    Irwin Bolt Grippers
    Dont know who first mentioned these on here, but they are the mutts nuts [:D]
    i used them on my rounded caliper bolts and they wipped them off no bother
    thanks to who ever first recommended them:clap: saved me load of hassle:clap:
  2. Mike_H Forum Addict
    I used mine last night... when you've got room to use them, they're great.
    Used it with a 22mm socket, and an impact wrench, ripped the rusted caliper carrier bolts off a Mk2 rear beam.
  3. mk28vICED Forum Member
    Rugby
    absoloutely brillant tool, especially on caliper bolts! when hitting a spline tool in fails! they do the job!
  4. mk1beast Forum Member
    scotland
    where can i get 1 of these ???
  5. Supercharged Forum Member
    Screwfix or machinemart are probably the cheapest places to buy - if not eBay...
  6. G60KG
    G60KG Forum Member
    at work 'working'
    wuold this help with my snapped alternator bolt? Ive only got 5mm to work with and that is on the end of the bolt so no sign of a head etc..
  7. ambrose89
    ambrose89 Forum Member
    on back,crap in eyes, beneath car
    yes, ideal
    can anyone source 6" ones??( they do exist)
    but i think they are rare(but not oak green)
    most makes only go down to 8"
  8. G60KG
    G60KG Forum Member
    at work 'working'
    what bit would I need out of the Irwin set to grip that bolt size. I dont want to by the kit and not have the right size bit for the job. Unless Im missing the point and the bits fit a variety of bolt sizes- I dont really understand how the tool works to be honest
  9. Matt82
    Matt82 Forum Addict
    GTI Scene
    the irwin socket has a reversed thread so as you put it on the shagged bolt and turn anti clockwise, the irwin bolt grip screws itself on to shagged bolt, gets grip and you can start to loosen it.
    look on google
  10. ambrose89
    any size, but id go for the smallest stilson (8")
    you just open up the jaws, slide them around the bolt, and turn like a spanner.
    the jaws bite into the bolthead/threaded bar and it undoes
    chews up bolts, so best to replace them
  11. G60KG
    G60KG Forum Member
    at work 'working'
  12. Matt82
    Matt82 Forum Addict
    GTI Scene
    that is an irwin bolt grip set.
    the pic above though, is a stilson
  13. ambrose89
    sorry its a stilson.
    but it will get the stud out and is a very handy tool to have.
    cost under a tenner for a cheap one.
    those bolt grippers are useful too then?
    i suppose you use these in restricted areas where a stilson wouldn't fit, but a socket would
  14. Matt82
    Matt82 Forum Addict
    GTI Scene
    yeah, they do work well if you dont have the space for a stilson
    once you get them out, grease up the new bolts and torque them properly to avoid this sort of grief in the future [:D]
  15. RIP-MK3 Forum Addict
    sunbury on thames
    i have just ordered a set of irwin bolt grippers, although the place i got the from had two they could order, one was called an expansion set and was 19.99 and there was a 'base set' for 28... i ordered the cheap ones (obviously!!! ha ha) anyone know what they have and/or what set i actually need??
  16. G60KG
    G60KG Forum Member
    at work 'working'
    I think the expansion set is just more sizes so you need to find out what size you need and then figure out if that size is in the base or the expansion set.
  17. Mike_H Forum Addict
    They're just different sizes, and the base set comes with a case, which holds the expansion set too.
  18. altern8 Forum Junkie
    Cocos (Keeling) Islands
    I bought the expansion pack and its the wrong ones doh
  19. RIP-MK3 Forum Addict
    sunbury on thames
    oh :( I haven't picked mine up yet but if they are wrong I will get the shop to order the other one's.... gutter
  20. paultownsend Forum Member
    machine mart do them @ 20 a set. one of those 'must have' tools
