Is it worth having a full list of abbreviations?
Discussion in 'Throttle bodies & non-OEM ECUs' started by A.N. Other, Mar 26, 2010.
    MAP
    WOT
    TPS
    even ITB, NASP
    etc
    ... it can all get a bit much if you're not quite in the know.
    Just an idea? If someone wants to run it, please do and I'll ditch this opening post :)
  2. Toyotec
    Toyotec's list of tech acronyms terms used on this forum.
    TPS Throttle Position Sensor
    ITB Individual Throttle Body
    NASP or N/A Naturally Aspirated
    MAP Manifold Air Pressure
    AFM Air Flow Meter (Vane type)
    MAF Mass Air Flow
    HFM Hot Film Meter
    MAT Manifold Air Temperature
    IAT Intake Air Temperature
    CLT Coolant Temp
    CKS CranK angle Sensor
    CPS Crank Position Sensor
    CAS Cam Angle Sensor
    SD Speed Density
    LBT Leanest (mixture for) Best Torque
    MBT Minimum (timing for) Best Torque (early discription) or Max Brake Torque timng (more widely used)
    BLD BorderLine Detonation
    DET DETonation
    TB Throttle Body
    MT MegaTune
    WG WasteGate
    alpha-N Throttle angle vs engine speed
    FMIC Front Mounted InterCooler
    OBD OnBoard Diagnostics
    DLC Diagnostic Link Connector
    OBD1 Mandatory US emission monitoring std ver 1 to 1995
    OBD2 Mandatory US emission monitoring std ver 2 from 1996
    EOBD Mandatory European emission monitoring std from 2001 for petrol and from 2003 for diesels
    MY Model year
    PID Proportional Integral Derivative.
    A/F Air Fuel mixture
    AFR Air Fuel ratio
    Lambda λ, ratio of stoichmetric air to air excess or deficiency.
    deg Degree of temperature
    PS PferdeStrke -German unit for measuring power. 1 bhp = 1.01 PS so 312bhp = 315.12PS
    TQ TorQue
    BHP Brake HorsePower
    VR6 Vee Reihenmotor 6 ( Vee inline engine 6 cylinders)
    Anchor - see VR6
    VAG Volkswagen AktienGesellschaft
    VDS Vagcom Diagnostic Software
    EBC Electronic Boost Controller
    EVC Electronic Valve Controller HKS term for their range of electronic boost controllers.
    ECU Electronic Control Unit
    ECM Engine Control module
    PCM Power Control Module similar to ECM or ECU. PCM used in the days when TCM and ECM where combined.
    TCM Transmission Control Module.
    ETB Electronic throttle body also know as E-Gas
    M x.x Bosch fuel spark and emission engine controller
    ME x.x Bosch torque coordinated fuel spark and emission controller with ETB
    MED x.x Bosch torque coordinated fuel spark and emission controller with ETB and direct injection
    CE1 Central Electric fusebox associated with Late MK1 Golfs and early MK2 Golf superceed by CE2.
    CIS Continous Injection System in open loop also known as K-Jetronic.
    CIS-E as above but with lambda feedback for use with catalyst systems
    N75 VAG reference number for wastegate soleniod valve
    T-MAP Turbo pressure sensor that can read absoulte pressures in excess of 100kPa
    IVVT Intake Variable Valve Timing
    TiVCT Twin Independant Variable Cam Timing.
    TCI-h Transistorised Coil Ignition- hall input.
    Brain gone dead again...
  3. G-Man Forum Junkie
    By the petrol pump
    WTF? (What the fudge) :lol:
    Yes please as I only recently worked out was WOT (Wide Open Throttle) was :lol:
    DBW - Drive By Wire
    CTS – Coolant Temp Sensor
    BOV – Blow off Valve
    AIT - Air Intake
    PCV - Positive crankcase ventilation
    I give up :lol:
  4. EZ does it Forum Member
    Coventry
    I think MBT is actually Maximum Brake Torque, i.e. MTB timing if you're talking about spark timing.
    Sorry to be pernickety Toyotec, I don't know half of the other ones in that list [:$]
  5. Toyotec
    Actually means the same thing. MBT timing is where maximum torque is achieved for a giving A/F. Increasing the spark angle beyond this minimum does not increase torque any further and will only lead to combustion instablity.
    I am not aware of the term "MTB"however.
  6. tshirt2k
    tshirt2k Forum Junkie
    Herts
    I though MTB was MounTain Bike :lol:
  7. EZ does it Forum Member
    Coventry
    Sorry, meant MBT, got mountain bikes on the brain. If we're being really accurate though, minimum isn't the best way to describe it though, since it's just a point.
  8. Mikey C Forum Member
    it isn't just a point though, it usually rolls over the peak, so you set the timing at the minimum for best torque, since there's no benefit in going any earlier.
  9. Dave
    Sligo, Eire
    Can we also have a sticky with all of the post acronyms please?
    LOL, etc.
    I have got IIRC, and IMHO, but that's about all.
  10. keith_lemon
    keith_lemon Forum Member
    on the edge.... also north wales, close to rhyl
    is there a way for certain abbreviations to link to a "speech bubble" giving the meaning of it - like these free forums do for advertisements?
    if it is too hard don't worry about it!
  11. Toyotec
    Tell you what...I like that sig :thumbup:
  12. The db
    The db Forum Junkie
    MK & High Wycombe
    Very useful thread!
  13. 16valver Forum Member
    Your not the only one!
    Quite embarassed to say, I only just worked that one out the other night.
    Like Toyotec's abreviation of 'Anchor' :lol:
  14. A.N. Other Banned after significant club disruption Dec 5th 2
  15. Ess Three Forum Member
    Aberdeenshire, UK.
    I missed that first time around. :lol:
  16. badger5
    nr Glos
    DTH-direct to head as in throttle bodies
    DCOE-a flange type associated with carbs and throttle bodies
    VR Sender = variable reluctance (crank sensor)
    Hall sender = other crank sensor type
  18. Admin Guest
    NOS - Nitrous oxide system.
    ABS - Advanced Braking System.
    TCS - Traction Control System.
    LC - Launch Control.
    PCB - Printed Circuit Board.
    DSG - Direct-Shift Gearbox.
    SC - Stability control.
  19. seanr68 Forum Member
    Dewsbury
    PCV and FPR anyone???
    I am such a noob.:lol:
  20. Breadfan83 Forum Member
    Doppel Schalt Getriebe. ;)
