so I really only have driveshafts and a Downpipe left on my Lupo conversion. Firstly some info, gearbox is an o2j from an Octavia with 110mm cups. Hubs are 1.0 standard Lupo. So im considering: a) stick with original lupo driveshafts for the outer cvs and find inner CVs that will fit, be it 110mm or 100mm inners / cups. Cut shafts to fit. But how do i know which 100mm / 110m inner CVs will fit my lupo shafts? b) some kind of hub change that will allow me to use the larger original octavia inner CVs, cut to fit c) completely different shafts from a known vag setup that will fit both 110mm inners and the lupo hubs, cut to size. Any help would be appreciated.
